17sport
Just thought I would share some of fuel economy data for anyone considering a drop-in filter and wondering the impact it will have on their fuel economy as when I purchased mine I saw many claims of improved performance/mpg. The truck was purchased in September 2018 and I installed the AEM Dryflow filter in January 2019. Over the two years the AEM filter was installed it was vacuumed out twice and washed once.
I have a fully loaded 2017 1500 Sport Crew Cab. The truck has a tri-fold tonneau cover and sits on 20x9 moto metal wheels with LT305/55r20 Nitto Terra Grappler G2W tires which I keep inflated to 42 psi. The only change to truck over the period of fill ups was an oil change.
The blue line below is when I changed from the AEM Dryflow drop-in filter to the OEM filter and I had left out the fuel economy for that tank from the average calculations. When comparing the overall averages it seems that the OEM filter provides better fuel economy. I have also calculated the average for comparable periods (for those that say winter/summer blends has an effect on results) and the AEM filter shows slightly less fuel usage but that can just margin of error. Also based on the comparable periods I took out the best tank from each set of data as they seem to be outliers and the OEM filter again shows better fuel economy.
I know that there are many factors that can effect fuel consumption but hope that providing hand calculated data over a few thousand kms and averaging out the results can help level out some of those variations.
