Aeroforce Guys...
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
Put in my Aeroforce, but it doesnt turn on. Am I stupid or just ignant?
Isnt it as simple as pluging the OBDII cable into the back of the gauge and then into the OBDII port? Or is this one of the few vehicles that requires external power using the center wire of the cluster of 3?
truckin151
2013 sport
Should just be plugging the cable from the obdII to the gauge. Check the gauge wire and be sure its in the right spot AND that its in there tight, mine kept coming loose
truckin151
2013 sport
Oh and turn the key on.... but you probably already guessed that one
RubberFrog
I believe the 03 needs a separate power wire. Have you checked on the aeroforce website?
Are you sure it is the right gauge for your year? Aren't there two different versions, one for the early rams and one for the later rams?
AF_Hemi
AF_Hemi
Yeah its the SR model. I couldnt find anything on the site that said 03 requires a separate power source. Maybe i'll just hook it up and see if that worksl
Doesn't RT-VA have the AI and an 03? Maybe you can ask him if you need it.
truckin151
2013 sport
I dont know that there is a power wire to the gauge. The seperate wires are for connecting to the other display sensores and those have an extra power wire.
AF, I checked out the manual for my AI and it says "If the gauge is not turning on or off properly you can force it on and off at the proper time by removing the small 2-pin jumper on the rear of the gauge and connecting the red wire to a switched 12v.".
AF_Hemi
AF_Hemi
yep thats what im gonna do. I'm pretty sure the middle wire of the 3 is a 12v power. From the manual "The center pin is an input only for switched 12v power, it is not to be used as a source for 12v power for external sensors".
I'll hook up the switched power to the center pin, and remove the jumper and see if that works
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The more and more I keep reading about these the more and more I want one.
It is a great gauge. You won't be disappointed if you get yourself one.
truckin151
2013 sport
Damn to think how not so used this gauge was about a year ago to seeing so many people with it now. What a change. Over on the other site it was just me and froggy with one and look how it blew up after that. It really is a great gauge.
