AEV Switch Pod installed
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
Wish i could come meet up with ya'll and show mine off....lmao
Ramm5.7
So Cal
Lmao
projectevaunit01
Buford, Georgia
Very new to these switches, do the Contura switches offer a (on) none (on) mode? Where the up position of the rocker switches one device on then the rocker springs back to the middle neutral position, then down will switch another device on and then back to middle. Do the same to switch off. Essentially getting two switches in one v series switch. I would like to be able to control 12 devices from the 6 switches this pod will accommodate.
This is this but I wonder how much of the pod I will have to modify to make it work and look nice
http://www.carlingtech.com/electronic-switching-products-ckp-series
Sent from my XT1635-02 using Tapatalk
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
JB, any chance you could add a full parts list to this? Better yet, I'll send you my stuff and you could work that voodoo magic on my parts :)
bigred74
Illinois
1999 and 2017
5.9L Magnum and 5.7L hemi
Yes!! I'd join this party and bring the beer!!
Ramm5.7
So Cal
How did you wire yours?
Carefully.....lmao
Its a self contained system. Oem Switch assembly with a fuse/relay box under hood. Plug n play connections to factory wires feeding switch with load side harness to relays. Hot from batt to one side of relay and light wires on other. System is negative (ground) switched like factory
shadowhawk
Southeast WI
so would all the power leads from the accessories feed into the bottom of the fuse box?
BinaryData
Washington State
I was actually looking for something like this. I'm not sure if it's worth upgrading my 09 RAM 1500 for something like this. However, I think I can make this idea work for my 79 F-150.
OC455
Central NY
Over the year I started adding more and more electrical items to my truck so I decided to add the AEV 6 position switch pod part number 30601000AA to the dash. I designed a schematic, ran it by @IRSmart a few times to check my plan and started ordering the parts.
https://secure.aev-conversions.com/shop/products/interior/switch-pod-for-ram-trucks
The power distribution box is made by littlefuse HWB60 and worked well. I ran the trigger wires inside the fender like the other oem wires are.
http://www.littelfuse.com/products/...modules/hard-wired-pdm/hwb60/pdm21001lxm.aspx
The switches are from OTRATTW (Over The River and Thru The Woods)
https://otrattw.net/LOWER-INDEPENDENT-LIGHT-UPPER-DEPENDENT-LIGHT-SWITCH-ONLY/
The rockers are Contura XIV, they have a good feel to them and have a "separation" molded in to distinguish upper or lower.
https://otrattw.net/CONTURA-XIV-ROCKER-ONLY/
I used @kad method of entering the cab via a rubber boot.
http://www.ramforum.com/threads/ins...nning-wires-into-the-cab.117923/#post-1696482
I routed the wire bundle behind the head unit and up thru the top of the center stack. I then added the mating connector to allow easy removal of the switch pod.
The wiring schematic is perfect. Thank you.
shadowhawk
Southeast WI
I see the red terminates at the fuse block for power, and you've used a separate color from the relay to the accessory. I guess what I'm after now is a picture of the multi-color wires into the fuse box then.
JB1
JB1
Houston, Texas
I use only GXL automotive grade wire made in the USA from wirebarn, you can pick any colors you want it’s just nice to have different colors so you can match it from the switch to the light itself. All the wire in the cab is low amp so you don’t need a heavy gauge, it’s just to trigger the relay. The wires from the box to the lights are thicker gauge since they carry the load.
https://www.wirebarn.com/BLACK-14-Gage-GXL-Wire-_p_76.html
shadowhawk
Southeast WI
I bet that picture was in the first post too, and I just missed it. Thanks JB. You're a peach!
JB1
JB1
Houston, Texas
Lol....sorry I don’t have more pics, I never intended this to be a “how too” since it’s so custom to my setup.
Here’s a schematic of just the power distribution box with wire size and cut lengths, sorry about the pic quality I just printed it and took the pic from my desk at work
anitamack
