Aftermarket e fan
Ajwalk2008
Springfield, il
Looking to do a after market Efan and was wondering what you guys have done and where you have put the screwing temp sensor if you are using one
allenmartinjr
Tulsa
6 years later and I came here to ask this exact question. Its disheartening to see no one has answered this one.
crazykid1994
Only difference is I have a 2017 so it’s a different fan than you need but there are drop in fan kits for a 3rd gen. You could use my temp setup
Ole Buck
South Alabama
I just installed a flex a lite efan on my 1500 4.7 it said to place the probe in the fan up near the upper radiator hose. Mine works perfectly. Flex a lite also make another harness that has the screw in sensor that goes in the top of your block where the radiator hose is that has your air bleed set screw is in.
