Alfa obd error
GeauxApe12B
GeauxApe12B
Georgia
6.7L Cummins
That bypass you have is only bypassing the CAN C bus (only plugs into one junction block).
The hvac module is on the CAN IHS bus, which is not being bypassed on your truck with that particular bypass.
Ok, so can you point me in the direction of the correct bypass? Thanks!
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I'm gonna step out and just listen now. You probably have the most authoritative source on the internet for AlfaOBD in @Jimmy07 !
Jimmy07
GeauxApe12B
GeauxApe12B
Georgia
6.7L Cummins
Ordered...thanks!
Jimmy07
dang, big spender
i got one of these for my wifes '17 journey and it works just dandy
It’s not practical for the OP to use that one on his truck, because the radio has to be removed to use it.
The one I linked just plugs into the obd port and junction blocks near it.
diymirage
Banned
practality has a price
im can have the radio in my truck in and out in 15 minutes
now, is 15 minutes of my time worth the difference in price between those two cables?
honestly, that depends on the day
GeauxApe12B
GeauxApe12B
Georgia
6.7L Cummins
I had one like that for my 5th Gen
GeauxApe12B
GeauxApe12B
Georgia
6.7L Cummins
Since this other bypass cable has 2 connectors, where does the other connector plug in?
Ftw_fydrinkitup
Maryland
Ive been looking for a security bypass for my 18 ram 1500 laramie thanks for this info
303STI
Colorado
Cummins 6.7
Since I'm dealing with heat issues on the drivers side, I tried using the Ms can blue adapter to calibrate the blend doors but keep getting an error. Any clues as to what is going on?
Reviving an old post but I have the same "drivers side no heat" issue with my 2019. Curious if you ended up having to use BOTH the MS-CAN blue adapter and Kaodtech SGM Bypass cable?
GeauxApe12B
GeauxApe12B
Georgia
6.7L Cummins
I ended up using the KAODTech bypass. However, I ended up swapping the hoses around leading to the heater core to let the engine reverse the flow. It's been extremely hot since and I haven't switched them back. When I do, I have a coolant filter setup that I'll install leading into the heater cores bottom hose.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Highly recommend flushing the system. I have experienced personnally (and see reported across all RAM engine types) sand in the coolant (possibly from the manufacturing process). Here is what I found in my factory coolant when flushing.
