CRUS8R
New to the forum...I have a 2023 Ram 1500 Laramie 5.7 Hemi. I read all of the threads regarding AlfaOBD and purchased the appropriate bypass cable, MX+ bluetooth programmer, and AlfaOBD app from the Google App store. I watched several videos on backing up my factory setting and performing some of the common changes on Rams. Anyway, I go out to my truck to do a simple adjustment (disabling my seat belt alarm) after performing a backup just to test the capability before making a serious adjustment. After making the adjustment a performed a cycling of the system by turning off my truck, opening/closing my door to turn the radio off, and waiting about 2 minutes. After that, I replaced the cables into their original ports and took it for a test ride in the neighborhood. After maybe a tenth of a mile, the seat belt alarm started dinging (change failed). I repeated the same sequence a few more times, but to no success. Then I tried to change the steering wheel setting to high, low, off, and that did not work either. I know my AlfaOBD works b/c I was able to retrieve my factory setting and upload to my google drive, but I don't know what I may be doing wrong.
So, my question is, what is going on with such a simple change not working? Has anyone heard of this, and do they know the fix to get these program changes to stay in the settings within the truck's computer? Thank you in advance if someone has encountered this and can point my in the right direction!
I ask this b/c I'm about to get a lift and new tires...And I don't want to have to take my truck to the dealer to get the tire size, ABS, and any other programming done to my truck to make corrections that AlfaOBD is supposed to do.
