Focker
- Jan 7, 2019
- 52
- 31
- Location
- Tri-Cities WA
- 2009
- Cummins 6.7
followed Focker's instructions and BAM!
Congrats on your DRLs and stay warm!One question... can this OBDLink MX and AlphaOBD app be used to turn on the turn signal lights in my tow mirrors to run with my parking lights? Not as DRLs, but when my parking lights are on, I want my mirror signal lights to illuminate also. Can this be done? Or do I have to go with the wiring method I found?
Thanks so much!! Those pigs in slop don't have anything on this girl's level of happiness right now!
I wish I could be proven wrong but the Alfa program will not be able to enable mirror signal lights as running lights at night with the park lights. The wiring method is the only alternative I am aware of right now.
I have enabled and disabled DRL, set the DRL to fogs, fog lights on with Hi beams and lane change indication on my 06 3500. So it should do what you need.I have a 2006 1500 ST, meaning manual windows, manual locks, no fog lights, and not even cruise. I figure 2006 Rams are supported by Alfa because 06-08 used CAN-bus.
Anyways I know Alfa for the older 4th gens and 3rd gens is pretty uncharted, but theoretically I should be able to enable these features through Alfa as I install them?
So I have an 09 1500 hemi just wondering what's the benefits or options alphaobd would help with. Truck is nearly stock except for hid lows and fogs and LEDs elsewhere. What can it enable dont wanna make the leap just yet if I dont know what I'm getting into
Where do you adjust the TPMS thresholds?
Also, I used the cheap ($12) Ebay "modified ELM327" for Fords (use FORSCAN on Expedition). Worked great and just rec'd the OBDLINK SX - haven't tried it yet.
Supposedly you can set the light type for each exterior light to halogen, led or hid. That should end the issue with LEDs in turn signals hyper flashing.Is there an option disable the "hyper" blink via AlfaOBD if LEDs are installed on a '11?
I'm driving so can't hook up and look right now, but it was my understanding we should be able to set light type for all lights? If the option isn't there maybe send an email to developer and ask him.I think I seen the option but didn't know if that was only for headlights?
