AlfaOBD TV
Gixxer750
N. Idaho
2015_2017
I'm not having another luck either. If I do not connect to the dongle but open alpha and go to the radio and open the list of options I see what is much more similar to what I did with the last ram. Once I connect the list changes. I've made all the changes that I can even fathom, but no luck. I can't even get a video signal while in park. I think I have connectivity issues. I felt optimistic when I had audio at all times, but im getting a little flustered so may just hit pause till I feel rambunctious again
Terry2014RAM
OKC
Reposting info here in a separate thread with more detail for anyone interested...
2 LockPicks have failed on me so I won't go that route again. I had every input on the LockPick in use so I was left with a Digital TV tuner and front/cargo/left/right cameras inoperable.
@Mpgrimm2 let me know about some tricks others on the forum had figured out to get a front and/or cargo camera working using AlfaOBD.
So I've run switched ACC power to power all of the aforementioned accessories and I have a (cheap) manual RCA switch which shipped quickly by air from from Korea...
RCA switch
I've turned on the cargo camera with AlfaOBD and used @Mpgrimm2 's $20 camera harness for video.
AlfaOBD Cargo Camera Settings to enable:
VehConfig 1 - CHMSL Camera
"Yes"
CBC Features - LED CHMSL Lamp Present
"Yes"
If you stop here, you'll have a working video input on the on-screen cargo camera button.
I then removed the factory pins for the radio AUX input at the back of the radio and inserted my own re-pinned RCA Jack's for right/left audio on pins 6/7 respectively...
I now have left/right audio and video for Digital TV on the 8.4 screen.
DTV
To watch TV, I currently select the AUX input for audio and then switch to the cargo camera (and I wait for my wife to come out of Target). I probably could have left the factory AUX jack useable by just tapping them for my audio, but I decided that was more than I cared to try after discovering I no longer even owned and AUX cable.
I use the cheap switch which I placed in my glovebox for now to leave it on front camera for most of the time...
Front Camera
But I can also select the other two cameras or DTV if needed without opening the dash up...
Cargo Camera
Right Mirror Mirror
Costs
Cameras used (front/left/right) $17 each
CNGATE Front Car Camera |360 Degree Eyeball CCD Waterproof Front Car Camera with Wide Angle https://smile.amazon.com/dp/B00AWRAYA2/ref=cm_sw_r_cp_apa_i_uFzrEbQB6Y9Y6
Mpgrimm2 RCA harness (x3 if you want video/left audio/right audio) $20 each
DTV receiver (this one gives you an extra input) $50-$70
https://www.ebay.com/itm/Pyle-View-...44720.c10&nordt=true&rt=nc#vi__app-cvip-panel
This is the smallest/cheapest video only RCA switch I could find $20ish...
https://www.ebay.com/itm/4-Port-SIN...1?pageci=e9fa0da2-1c5b-4632-a89e-5e3a45b702a2
There are many options for the cargo camera and I no longer would recommend the one I'm using because while it is good it has more than doubled in price since I purchased it.
That's it! Much cheaper and likely more reliable than a LockPick! It was $50 to have the first LockPick replaced UNDER WARRANTY!!! You can get AlfaOBD for that much! AlfaOBD wins again!
Mpgrimm2 I also have Cargo Cam setup like him but I do not have the the buttons during camera view to change to change between revers and cargo. I recently retrofitted my 2014 Laramie 5.7L to the 2018 UAQ. Everything else is working fine.
Any thoughts?
I recall that the Lockpick back in 2009/2010, had to have a wire attached to the foot brake.
It fooled the Video input to believe that the vehicle was Parked with the Brake on
SitKneelBend
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Any thoughts?
The AlphaOBD instructions in my post are what you need to implement. Two config changes.
diboblo
California
@SitKneelBend
Will you provide a part number, for the pins you used to build your audio aux input harness?
PM is cool. Don't want to clog the thread.
Going to try adding wireless hdmi, to my rig.
Thanks,
Bob
SitKneelBend
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
@SitKneelBend
Thanks,
Bob
@Mpgrimm2 made it for me. He makes loads of custom harnesses for our trucks. I'm not sure if he still makes these though.
BoBoway4
