Ghost_RAM
@Michael Dent Yours is currently set to "External Port Type: AUX + USB + extra USB"
What are the faults are getting?Has anyone used this to reset airbag system faults. Added a new clockspring on my truck. Accidently created a fault after getting the wheel airbag put back in.
Do you know what would change the radio hardware setup causing the SD card to not be seen. It is as if my 2016 Rebel is seeing the radio as 2017 radio when the SD card was removed.
Yes it wasn't available unless your truck came with an RA3 or higher radio from 13 to 16. It was discontinued in 2017 for some reason.My 2014 does not have the SD card either, just USB and Aux. I think it's a trim level thing.
This is the setting in Alpha that controls which of them you have.
ECU Configuration 3:
-K
Thanks I will look at thatI'll take a look. You can in the mean time look under ..
External Port Type: AUX + USB (My settings) Yours would be the one with SD
Awesome response and feedback
That should solve the problem I will try soon and update
OK solved the SD Card Reader issue - THANK YOU
But still missing an active XM Source and an active antennae setting for FM and AM. FM and AM show up in Radio but no way to tune to a station/frequency - weird.
XM is completely missing.
I tried looking thru settings and could not see where at add or adjust. I did see antennae settings - what should it be set to?
You are awesome for your help so far
United States of AmericaSome additional information:
my ECU Confg 3 Country of destination is set to Sweden.
When I go into alphaOBD to change it asks me to enter a value?
Since you have a Rebel, I'm unsure but you have ECU Configuration 3: Antenna Type: Passive Primary and active secondary antenna. Mine is set to Antenna Type: Passive Primary and no secondary antenna.OK solved the SD Card Reader issue - THANK YOU
Thank you guys for your help! New module will show up tomorrow so we will see for sure then! I’ll keep you updated. I did some more Alfa research and I’m hoping abs initialization will do the trick if anything is required. So thanks for that tip! As for the $45 fee my dealer said that’s any charge for hooking it up to the computer. Need a key fob programmed? $45. Need drl turned on? $45. Buuttt... I’m feeling pretty cool with Alfa knowing I don’t need to depend on a dealer. Also that dealer is about 40 mins away, I always make this trip because my local dealer absolutely sucks! My mom got threatened by the service techs after she said she was sick of waiting 2 hours after the expected finish time! Oh boy.. And last but not least the truck isn’t under warranty. It’s a salvage title that I rebuilt, had significant front end damage but I will be into a 4th gen Ram with the EcoDiesel for about 10k less then blue book.. now let’s just hope the engine doesn’t fail like everyone says. Thanks again to everyone that helped and I’ll let you know if Alfa works!(if needed)I have never replaced the ABS module on a newer Ram but I have replace several on other cars and it is a very straightforward and simple process and no programming was required. In most cases the ABS module attaches to the ABS pump when the module is replaced the actual ABS pump does not need to be bled because it does not need to be removed.
New release of Alfa for Android. Says bug fix release, have not noticed any differences yet.
Sent from my Nexus 6P using Tapatalk
Unfortunately it asks for a blue and I cannot enter anythingUnited States of America
I wonder if this is why my radio has no frequecy
