No, I have my DRL set to low beams. Mine was acting funny because it threw a park lamp out message on the EVIC but, when I checked the code it said "Short circuit to battery right turn signal". The first night I set "LED front turn lamps present" to yes and it did not solve the park lamp message. The second day I also set "LED front park/marker lamps present" to yes. After the truck had sat for close to if not 24 hours the message went away and when I checked my codes with Alpha it is now gone. Check and make sure you have both of those set as I stated above. My switchbacks run white running light with the headlights and when I hit the blinker they then go to amber. I will post the screenshot again below so you can see what I enabled.
17' CCSB 4X4 68RFE 2500 6.7 Tradesman DRP EGR delete, CTT tuning w/TCM tuning, UAQ w/7 speed HVAC, 7" premium EVIC, OEM front Parksense, OEM style front camera, aux switches
