That's the one I cannot find in the list to turn on. It is in the BCM, correct?
you need to undo the led low beam setting and only enable "VehConfig 3: High Intensity Discharge Headlamps"Hey guys I’m new to the forum. I recently purchased led bulbs from xenon pro for my 2015 ram with projector. With the low beams installed anti flicker can bus. they would work then after 10 min of driving they would shut off. I purchased the Alfa app changed settings in the truck to low beam led took out anti flicker can bus. The low beams will shut off when the truck is running. And don’t stay on as long. I let the truck sit after making changes. I’ve tried with bi xenon enabled or disabled and still having no luck. Is there something else I need to change?
I’m the list of modules to connect to, you choose abs instead of body computer.Advanced? Not sure how to do that.
If you successfully updated your tire size, and you don’t have a bunch of lights lit up in your EVIC, then don’t worry about it.I think I will stop while I still have a drivable truck. The video I watched is in NO WAY the same as what I am getting on my tablet. The video shows next step to look for ABS then select ABS Ate/Continental... that is nowhere to be found.
You on windows or Android app?Actually it seems to have been set at 2700 mm. I tried to reduce that number (to lower the speedo reading a mile an hour) and got the lights on the dash etc... Couldn't find the ABS Ate/Continental in the next step I had written down so I changed it back to 2700 MM and no lights on the dash.
I only upgraded to 275 65 Coopers from Wranglers SRA 275 60's so it not that big of a deal, but the perfectionist I am want the Speedo spot on.
