TjayM
- Dec 19, 2019
- 8
- 9
- Location
- Alberta, Canada
- 2013
- 6.7 Cummins
I think I screwed up my truck!! please help.
I've been trying to get my HID's with a relay harness to not give me Low Beam Headlight bulb out warning's today. did all the changes in BCM for HID, LED, Bi Xenon, etc. Nothing worked and I still have the error but that's not a big problem.
I was getting cocky using alfaobd and I decided I would change my odometer as I ran larger tires this year and never changed my tire size settings so my odometer is out a few thousand km, so I figured no big deal I'll just go in and add the km so that its right, so I did the procedure outlined exactly as it is here in this thread and as soon as the process completed and I came back the dash now has a ABS light on and traction control light, error code is "C2206 Configuration Mismatch" and I get a "Fuel Sensor error" on the dash and my fuel gauge is only reading slightly above half full when it is in fact completely full.
I tried removing the negative terminals on the battery for about 20 min, I tried doing the odometer correction procedure but putting in the original KM, I went into the abs module and i cant clear the code it just immediately comes back up, I tried going to the ABS Initialization but I press start there and it just hangs and nothing happens.
Please Help! I'm panicking here thinking that I just messed up my truck.
Thanks
*EDIT* using a Samsung tablet and bluetooth connection with OBD Link MX+
Thanks
