Ghost_RAM
Ok, I give up. What is "BIf"?BIf
First post. Should be just...
Puddle Lamp Present
Select “yes”
Mirror Turn Signal Present
Select “yes”
Haven’t tried this but it stands to reason.
It worked like a charm.
I originally had power fold mirrors purchased. The showed up with missing connectors and both turn signals cracked and my truck is all black so they were not going to work. These tow mirrors are perfect and now the signals work as well. I absolutely love not getting gouged by the dealer.
Yes I did. Reviewed changes in the log, and the only thing I see were the changes I listed above. When I double checked just now after the engine start, the check engine light seems to have cleared itself. Maybe this code isn't a big deal?Did you create a log before you made any changes?
Been waiting for this one. I’m not sure but probably so. I know you can turn off the ECO light but you can also do that on the screen. I assume you’re actually referring to disabling MDS?
I don't know enough about this to say for sure. However, if you feel you followed the procedures correctly then you could always submit a bug log to the dev.
Someone else might speak up but I don't think there has been too many people attempt this with Alfa?
Please do! I am going to attempt this soon myself.I did submit the ISO code error through the app to the dev. I’ll try again and post a screen shot of the errors.
So I tried to update the TPMS system but I ran into an issue. I was able to go in using Alpha OBD to change the tire pressure threshold but when I went and connected to the radio frequency hub I received an error about some kind of ISO code but was given the option to continue anyway. Once connected I tried to reset radio frequency hub using the PIN I obtained from the dealer. When I did this I received an error that said failed and that I didn't have security access. As I stated I'm using Alpha OBD as well as an OBD link MX Bluetooth. This was after having the dealer add the different sales codes for the factory options that I added to the truck. Has anyone run into this issue? Is it possible that gave me the wrong PIN number? They gave me a printout with both four digit and five digit numbers also showing my VIN number so I don't see how this could be incorrect. Any help would be appreciated.
Sent from my ASUS_P00J using Tapatalk
Anyone in Northern Alabama have an Autel that I could meet up with to reset the RFH. I could go back to dealer, but I dont know when I will have time, and it seems that AlphaOBD doesnt support the rest of the RFH yet.
My 2016 6.7 SLT came with cloth seats, no heat.
I put in a set of Limited heated/cooled seats as my truck came with fully populated harness.
When I set the heated seat material type to "Perforated Leather" ALL 4 heated seats and the heated wheel would turn on and kick off early. If I turned on the heated wheel it would heat slowly and kick off after a long time, if i turned on one seat it would barely heat and kick off after a while, If I turned on 2 seats or more it would kick off within seconds.
Once I changed the Heated Seat Material Type to "Default" ALL 4 work perfectly.
If you have access to an A E Tool or ALFAobd, check the "Heated Seat Material Type" setting and try setting it to "Default" to see if that cures the issue.
It's easy to Identify the cause of an issue when only changing ONE setting at a time...
