AlfaOBD
chrisbh17
Ahh OK. My older vehicles just use timers I think. Move mirror down x seconds then back up x seconds to end up about where you started.
Sent from my Nexus 6P using Tapatalk
clifford15
CTD
Not really sure. The factory remote doesn't and I would not think an aftermarket one would either. When you lock your truck the VTA sets itself and the only way I believe it will go off is if the truck is forcible opened. When your remote start it ensures the truck is locked then starts. You have to unlock the doors before entering so it would disable the VTA.
Thank you, sir. That makes sense that it would activate on intrusion. I wonder why they don’t turn on for all trucks.
Ghost_RAM
Ghost_RAM
VA
As with most things it more than likely boils down to money.
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
I am sure this is a long shot but I'll ask anyways. @Ghost_RAM
Has anyone seen any way to make the truck unlock the doors when you throw it into park? Had a few GM vehicles that did this and I kinda miss it. Haven't found anything in my searches.
Ghost_RAM
Ghost_RAM
VA
I looked for that one too and I haven't found it.
JOHRY
Ontario, Canada
EcoDiesel 3.0
So if I wanted to add heated seats. Is the wiring under the seats already there? Like if I got a set from a wreckers and installed them, then activated with AlfaOBD. Would they work? I know I won’t have the buttons, but the controls will be in my 8.4” radio right?
Ricks Ram
What trim level is your truck?
Ricks Ram
I have a Tradesman.
Unless your truck is a regular cab you will need to add all of the wiring in order for it to work. Check out the thread I started in the 4th gen DIY section ( Installing Heated/Ventelated seats and Heated steering wheel in and Express or Tradesman. M2Mods can make you a harness.
JOHRY
Ontario, Canada
EcoDiesel 3.0
Damn!
Ricks Ram
Damn!
Adding the wiring is really Not difficult at all if you use the M2Mods harness. It's basically a plug and play harness that they developed that is pretty much foolproof and looks just like factory.
61N150W
Anchorage, AK
Hey all, could someone point me to the "Nav turn by turn"? Perhaps I'm not looking in the correct module. Using the Android version.
Ricks Ram
The Nav Turn by turn usually works by default when you do the RA4 upgrade. The setting To turn it on and off on the screen with the alpha tool is in the car configuration screen about 3/4 of the way down in the CSM settings.
mtnrider
Georgia
Today I tried to enable the "Off Road Pages" and "Off road package". Can't see that it did anything. No new pages on the uconnect unit. It was a long shot I guess.
Ghost_RAM
Ghost_RAM
VA
I don't think the "off road pages" does anything for our trucks. If you enable "off road package" in both special packages sections in the BCM near the top, it will give you the Rebel splash screen on boot of the EVIC.
61N150W
Anchorage, AK
Cool thanks, will take a look.
This is with a 2018 UAS (Non-Nav). Couldn't find an answer if Google Maps/Waze/etc. were able to display turn-by-turn through evic, so was going to give that a try to confirm yea/nay.
Ricks Ram
That's a great question. When I had my UAQ radio in my truck I'm pretty sure it did not display in the cluster unless I was using the factory navigation. It's definitely something you can verify though.
WVRam68
WV
Hello all, has anyone had issues with uploading to google drive?
I select to do it, and it just goes back to select or create screen.
Thank you all for this, awesome thread, been using autel and AE, now this.
Thanks again
dav8388
Summerville, SC
In limbo between trucks
3.6 pentastar
So wait regular cab tradesmans have the wireing already?
Ghost_RAM
Ghost_RAM
VA
Thanks again
If you have followed the procedure in post 1 about linking and uploading to your google drive and are still having issues, follow the procedure in this post.
https://www.ramforum.com/posts/1830948/ Start reading here.
Do you have log recording turned on in the settings menu (inside first button at top of screen)?
Have you connected to your "body computer", connected to the BCM and clicked the battery icon at the bottom to click the "read system ID"?
