Ghost_RAM
Check the link I posted. No on 37s37s?
Sent from my SM-N950U using Tapatalk
Edit: The link is to the screenshots of all the available sizes.
Damn. Well 35s would get my speed a little closer to being right. Doing 68 when I'm really doing 75 could get me in trouble if I forget. Hate to get pulled over thinking I'm doing 75 when I'm really doing 85ishNope
37s?
The white plug on the ATC mirror harness is for the rain sensor if that's what you were referring too.@chrisbh17 Turns out, that cover for the rain sensor is actually the same cover I still need to pickup to cover the top section of my auto high beam mirror. Reached out to Benny earlier to inquire about the white plug left over after installing my humidity sensor. Not saying I'll do it now, but I for sure would if for whatever reason my windshield had to be replaced especially if I already have everything in place for the install minus the sensor.
That is exactly what I was referring to. Many thanks! Then I know I'm tackling this.The white plug on the ATC mirror harness is for the rain sensor if that's what you were referring too.
I should probably put out the disclaimer that I was told when I bought my harness that the extra plug is for the rain sensor. It makes sense that it would be. I can't think of any other option in that area that would require a connector. The only other option I know of are the cab lights and I'm pretty sure that harness is a different part number. I guess it would be worth a try as long as you could figure out how to mount the sensor in a way that it would function properly. If it did I would be definitely be interested in giving it a try as well.That is exactly what I was referring to. Many thanks! Then I know I'm tackling this.
I just put the Auto Dim/Humidity harness from an 2018 in my ‘17 and I have the same plug left over. In addition to the Rain Sensor and possibly windshield, what other equipment/hardware would be needed to make the Auto Wipers work?
Now you have us all interested.If you already have the harness installed, then I’m going to assume that you would need the windshield which would more than likely come with the bracket and pad. You would also need the top cover (you might already have if you installed the mirror covers). Then the sensor and programming. All of the above is purely assumptions as I have not done this yet.
What I’m possibly looking at is modifying my current windshield with a bracket, pad, cover and sensor. Then program with Alfa.
I’ll definitely be following this. It sounds like the position of this sensor is pretty precise.
Are you talking about the top cover for the rear view mirror?
Is the bracket available through Mopar or Aftermarket?
