dav8388
- Joined
- Apr 23, 2018
- Posts
- 362
- Reaction score
- 207
- Location
- Summerville, SC
- Ram Year
- In limbo between trucks
- Engine
- 3.6 pentastar
I already let Alexey know the problem sir. I sent him everything debug log and screen shots of what error I was getting and everything lol
2018 Black Pearl Ram 1500
LED Tail Lights, Black Quad Halogens with LED conversion, LED Black 3rd Break Light, Blacked Out Emblems, Rims & Grill, 8.4 UAQ conversion!, MTC to ATC Mod, OEM Remote Start
great ideas! would love to have those but I havent seen anything remotely resembling a setting for either one.Does anyone know if the wiring is in place for the cargo camera?
Also, with alfa can we set the tow/haul and engine brake to come on automatically when a trailer is detected? Engine brake stays on as long as you don't disconnect I know but you have to turn it on manually the first time. Tow haul you have to turn in every time you start the engine.
Waiting on my harness and obdmx to arrive. Getting a list of mods ready to go!
Thanks
You can set it up like the 3500's, I believe its the base TPMS system vs the premium. Look back some pages it was mentioned recently
Thank you for this, I just got back in from resetting the the RF HUB on Android and it worked like champ!
Also if you purchase the android version of the app there is a discounted price For buying both platforms. Email Alexey and he will send you the apk link and you will have to download and provide him with your PayPal receipt and your activation code from the android app. Think it was only $25 for the android after paying full price for the windows version.
Great tip, what is his contact info. Thanks
FYI I was able to convert from TPMS to TPIS
Body Control Module>
Car Config Change>
Base TPM System Present > NO
Premium TPM System Present> NO
Non Regulated Tire Pressure Information System Present > YES
Then Updated/Reset the RF HUB with the 4 digit PIN and No warning light
Interesting. I was wondering if that setting was to keep both DRLs illuminated when the turn signals were active. As it is, when I turn on my turn signal, the DRL on the side I am signaling will turn off until the turn signal cancels, at which point the DRL will re-illuminate. I'm guessing that is a native function to DRLs, then?
I believe (certainly I've noticed it here in NY) that the DRL HAS to drop out while the signal is active on the same side; I know that is how any vehicle, at least with factory-enabled DRLs, works regardless of the manufacturer and/or DRL location. It's a safety feature to ensure the signal stands out as being active.
Here's what I think is the applicable text of the Federal DOT regulations, under Title 49: Transportation.
"PART 393—PARTS AND ACCESSORIES NECESSARY FOR SAFE OPERATION:
§393.22 Combination of lighting devices and reflectors.
(a) Permitted combinations. Except as provided in paragraph (b) of this section, two or more lighting devices and reflectors (whether or not required by the rules in this part) may be combined optically if—
(1) Each required lighting device and reflector conforms to the applicable rules in this part; and
(2) Neither the mounting nor the use of a nonrequired lighting device or reflector impairs the effectiveness of a required lighting device or reflector or causes that device or reflector to be inconsistent with the applicable rules in this part.
(b) Prohibited combinations.
(1) A turn signal lamp must not be combined optically with either a head lamp or other lighting device or combination of lighting devices that produces a greater intensity of light than the turn signal lamp.
(2) A turn signal lamp must not be combined optically with a stop lamp unless the stop lamp function is always deactivated when the turn signal function is activated.
(3) A clearance lamp must not be combined optically with a tail lamp or identification lamp.
[39 FR 26908, July 24, 1974]"
Ok so I had the Android version and took Lawsuit's advise and got the Windows version too w/the discount. Can someone help me connect, I get an error message
"error opening port.The port COM1 does not exist"
Pick body control module
My13-17
Then go to advanced
Change com port to 2/3/4 or until it works. All depends on what your Bluetooth on your computer is set up for
Mine works best on COM3
Also if you go to post one. Ghost has a walk through for the COM port with pictures
http://alfaobd.com/AlfaOBD_Help.pdf
OK so I found and reset my bluetooth part of the PC system and now like Lawsuit11 said I'm on COM3 and it should be good BUT. The new issue is when I click connect button the PC just freezes (4 times so far). I made sure that I could go into the OBDMX itself and there were no problems there. I went to the Alfaobd app, checked the version and clicked repair and still have the same PC lockup problem. Did anyone else ever experience this? If I were to do a complete uninstall and try to reinstall would the same activation code still work?
For anyone who has done the "U05 AutoPark Functionality" recall, can this be reversed with AlfaOBD? I don't want the truck to automatically go into park if the door is opened.
