AlfaOBD
chrisbh17
Has anyone used the AlfaOBD after installing the Morimoto Xb FogLights so that you don't need the splitters and resistors ? ie by setting the fogs to LED fogs?
M² Mods.
I volunteer to try this, just need someone to buy me a set of xb fogs :)
Sent from my Nexus 6P using Tapatalk
Lawsuit11
Westland, MI
M² Mods.
I did this with my LED low beams. They flickered really bad without resistors I changed the setting with AlfaOBD to LED Low beams. No flicker at all. I can only assume this would be the same for the Fogs
2018 Black Pearl Ram 1500
LED Tail Lights, Black Quad Halogens with LED conversion, LED Black 3rd Break Light, Blacked Out Emblems, Rims & Grill, 8.4 UAQ conversion!, MTC to ATC Mod, OEM Remote Start
skuppy069
canada alberta
2018 1500 cc
M² Mods.
I installed the Xb fog lights and didn’t need any resistors etc
Been running for 8 months and not one error
I just simply plugged them into my stock connector and all was good
Ricks Ram
Do you have the premium 7" speedometer or the 3.5" smaller screen?
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Where they worth the upgrade?
M² Mods.
61N150W
Anchorage, AK
I converted from quads to projectors a few years ago using Jeremy's conversion harness (with resistors). I was excited to get my DRLs working with Alfa but have just recently noticed they flicker like crazy. I could seen it in the reflection from vehicles in front of me. Bad enough that I turned them back off. Is there a setting that may remedy this?
cclark019
Bay Area
There is a setting for DRL target voltage. Its set to 7.4 volts just change it to 12+ and you should be good. I had to do this so my LED Fog lights wouldn’t flicker in DRL mode.
JB1
Houston, Texas
M² Mods.
I had the resistors wired into the XB fogs for a year but a week ago I set the fogs to LED and then removed the resistors and plugged the XB's directly to the trucks wiring connection. They work great and I never got an error message. Another win for the alfaobd. My truck is a sport and I have the premium cluster and 8.4.
skuppy069
canada alberta
2018 1500 cc
On my 2018 ram 1500 I didn’t need to change anything in the bcm for the Xb led fog lights .
Curious if you tried then without the bcm change like me and see if they work like mine right out of the box .
I wonder if tne 18 didn’t include the fogs for bulb out detection versus other years of rams
JB1
Houston, Texas
No I never tried it, they recommended them so when I ordered the kit it included the resistors for $30 extra. Maybe yours is a Canada thing...I dunno
IF YOU HAVE A 2015+ RAM PLEASE BE SURE TO ADD THE SPLITTERS AND RESISTORS OPTIONS SO THIS KIT PROPERLY WORKS WITH YOUR CANBUS SYSTEM AND TO ELIMINATE HAVING BULB OUT ERRORS
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
My 2018 3500 worked with the Rigid fogs without any resistors. My ham radio says there is a lot of noise being generated so I'm guessing that they went to a higher duty cycle or higher frequency duty cycle that stopped the flicker. As soon as I get my unlock cable I'll be trying to set to LED to see if that gets rid of the noise.
skuppy069
canada alberta
2018 1500 cc
I’m not sure only one way to know is too set the bcm back and see if the truck throws a bulb out error
JB1
Houston, Texas
One things for sure, if you have the alfaobd don’t waste $30 on resistors
KiltedCelt01
PA
It looks like Alfa OBD is available for iOS now. Of course this happens a week after I buy the OBD link MX and an android tablet.
They’re also having a 25% off sale.
https://www.scantool.net/obdlink-mxp/
KiltedCelt01
PA
I was mistaken, you are correct.
Hemi395
Cape Cod MA
Today I went to activate DRLs and deactivate the fog light dropout and found out I have no CSM options under car configuration. From what I've read this seems to be a 2013 thing with Alfa?
I did manage to get the DRL option in my RA3 and they do work. I couldn't find anything related to the fog lights, any ideas on that?
Mrmagoolin
Pendleton OR.
Cummins 6.7
Were you actually connected to the truck? They don't show up unless you are.
Sent from my SCH-I545 using Tapatalk
KAKA
