AlfaOBD
jordanlbrt
US
2013 2500 mega cab
Are we able to perform a manual regen with Alpha? If so, where's the option. Thank you.
mtnrider
Georgia
Under the Engine module there is a "Stationary Desoot" function. Don't know anyone that has tried it yet though? Give it a shot and let us know.
jordanlbrt
US
2013 2500 mega cab
It's actually for a friends truck. I'm deleted. But as long as he's willing, I'll gladly give it a shot. I will post the results. Thanks
jdomke1
Manteca, CA
Just read through this thread and haven’t noticed anyone that has tried the Police option under special vehicles. I’m curious if that will give us access to having control of our cluster lighting brightness with the dimmer when the headlights are off. As it is now the cluster is at max brightness and will blind you at night.
I’ve seen a few people post questions about the police options but no one ever answers. I’m curious about this setting as well. Wondering what it actually does. Anyone?
jdomke1
Manteca, CA
My '14 is set as follows if it helps:
Vehicle Config 5:
Ambient temperature sensor location: Not defined
CBC Configurable Inputs and Outputs:
Ambient Temperature Sensor Present: Not set
-K
Just to follow up, putting it back to your recommendations worked. Thanks.
chrisbh17
I have a feeling it is there because there are police issued Chargers and Challengers, and probably wont have any effect on the RAM.
bryce88
Utah
There are police issued Rams too. I see them all the time here in Utah.
jdomke1
Manteca, CA
What does it do for those models? Someone mentioned wag-tag but that’s actually an aftermarket add-on that adds the external lights and ties into the stock lights.
mtnrider
Georgia
bryce88
Utah
I don't have personal experience with it but I would assume it could add menus for configuring lights, plugs, communication equipment, etc. Law enforcement vehicles have all sorts of things that normal vehicles don't, so it makes sense that the truck's computer would be equipped to be aware of and configure all those add-ons.
jdomke1
Manteca, CA
Yep....
https://www.fcausfleet.com/law-enforcement-vehicles.html
If you follow the link to the trucks there is a few PDF's of the police options. Some "upfitter" type stuff so that is probably what the police option is for?
Thanks. Looking at the Upfitter Guide I’m guessing it activates the relays they have under the hood, in the dash, and truck bed for add-on equipment.
1500ram12
5.9L Cummins
I was going through my logs and noticed that there is 2 different tire sizes listed and it doesn't appear when I changed tire size it took. When I changed it I put in 2776 mm just to see what would happen. I forgot to check my speedo against a GPS to confirm but driving yesterday didn't appear to have changed. So I changed it to 2751 mm which a 34.5 about what a 35 should measure.
As you can see it's saying that it's set at 2776. No when going into and looking at my logs you see this
Which is 33.1, stock tire size, along with this
Not sure if I'm missing something.
1500ram12
5.9L Cummins
I also went through and tried changing the fuel settings and this is what I tried
As you can see in the logs nothing changes
kad
Hudson Valley, NY
5.7L HEMI
Dealer: parts dept to be specific
This app cannot. There is another app out there that can (the name is somewhere in the last couple of weeks of posts here), it costs $15. But the dealer should give it to you for free. So unless you've got one of the brain dead dealers that refuses to give it out or getting to a dealer would cost you more than $15, the dealer is your best bet.
-K
kad
Hudson Valley, NY
5.7L HEMI
I had set the full on mine to 98% a week or so ago and I distinctly remember it making a difference in the gauge reading, but after seeing your post I went out and double checked. Sure enough, it was back to 91%. I set it to 98% again, shut it down for a bit and checked again. Back to 91% again. This is with the latest Android version and an MX dongle. Has anyone gotten the setting to stick?
-K
grozier
Independence mo
Who ever figured out the led DRL settings deserves a huge thanks and a handy. I could not for the life of me get my whites to be drl and the Amber's were burning at full amperage which would have burned them out. I've had these boards since early 16 and today I finally got what I wanted. Thanks thanks thanks. d1aae5f87c66a9bed2c6a7b8cb4027e5.jpg
Sent from my SM-N950U using Tapatalk
Tankerpilot01
Lawson, MO
Cummins
-K
What you’ll need:
1. Drivers license
2. Registration
These prove you own the truck.
They will then give you a “Key Code Inquiry” printout with VIN, ignition code and PIN.
grozier
Independence mo
Also I seen a spot to change voltage to the lights. Can i up the voltage a bit to brighten the whites? They don't burn at full power even though they're set to drl
