AlfaOBD
gapi
Georgia
HEMI 5.7
Thanks guys. I experimented on a 2013 Charger R/T Plus that also had mirrors upgraded to memory and drivers side auto dimming. They came off of a 2013 Charger SRT. Dual plugs with several wires in the white plugs.
We got the auto-dimming drivers side working and the fogs to not drop out on high beam. But no memory or tilt in reverse. No option to choose tilt in reverse.
We also noted there were no CMS listings. I guess it may be a year model availability thing, or is there another list for them?
WilliamS
Tampa FL
In doors section
Drivers side mirror memory (Yes)
Passenger side mirror memory (Yes)
Tilt in reverse in the custset menu.
(CSM) (Yes)
One thing to note is the (Tilt In Reverse) function will not work unless you have memory mirrors. You need to have more than 4 wires in the white mirror plug.
I havent pulled the mirror off yet, but I have folding, turn signal, heated, auto dimming. Id have a hard time believing they left the memory part out. I think a few guys said it was related to having memory seat door module?
chrisbh17
I have all of that without memory. They really are two different mirrors just with and without memory.
Most memory mirrors will have the chrome cap on the outside. I think there was a fairly rare configuration with memory but without the chrome, but I can't remember if that's true or not.
Sent from my Nexus 6P using Tapatalk
Ghost_RAM
Ghost_RAM
VA
3. Activated DRLs (via LED turn signals.
However, even though the DLRs are working, I don't see the option to turn them "off and on" in the 8.4" settings screen. I made changes as described in post 150. Do I have to wait a few ignition cycles for it to appear. Or do I have to reset the radio to factory settings? I did turn on and off the truck about 8 times in a period of 20 minutes or so. Confused...
As said before some settings take longer for whatever reason on different year models. If you have set the CSM at the bottom of the list in car configuration change then the setting should appear in your radio under settings/lights/daytime running lamps.
You can try a radio reset with holding the volume button and channel select button for a few seconds until the unit goes shuts down. Remember the DRLs also will not activate while in park or with the e-brake on.
Ricks Ram
All the door modules are memory capable. The only difference is power fold or non power fold. As stated the mirror options you have are common without memory. Almost all the memory style mirrors are going to be the chrome capped mirrors. Even though the Sports themselves never came with memory there are also a few painted versions that came on the Laramie trucks with the Sport appearance package.
Gibbs
GA
6.7L Cummins
Is there a CSM for auto dim rearview mirror (EC Mirror) under car configuration change?
I couldn't find one
Ricks Ram
I couldn't find one
No it's Vehicle config#3. If you have the 8.4 radio and you enable it the soft key should show up on your apps screen. Sometimes it takes several ignition cycles for it to show up. 4bf1a1d1b55af80370aa854bb34e8051.jpg
Gibbs
GA
6.7L Cummins
I did enable that setting last night but haven't had a chance to check it today. I just wanted to make sure, since there's usually a CSM to get soft keys to show up. Thank you for the confirmation.
719c6
You would select radio frequency hub for select function, then select wireless control module my2011-12 non PowerNet for control unit. Then select program ignition keys or key fobs and follow the instructions. Don’t worry about running “ELV/ESCL replaced” or “PEM replaced” as you don’t have an electronic steering column lock or a passive entry module.
Got home and programmed an additional key/fob. Thanks for all the help.
mxrider309
memphis
can I use this OBDLink MX+ with alfaobd software? instead OBDLink MX verison only?
I like this option of being able to use it with my iphone for different apps.
thanks for input
1500ram12
5.9L Cummins
thanks for input
Yes you can.
mdifilippo
NJ
Just setup my DRLs finally, have them set to the low beam for now but may change em over. **Thanks 1500ram12 for the answer below to this** Wish there was a way to disable them turning off when you turn on the blinker but i realize that may be a safety thing so that the blinker is more noticeable.
Now to figure out what other changes to make to the truck with this haha.
1500ram12
5.9L Cummins
Just setup my DRLs finally, have them set to the low beam for now but may change em over. Wish there was a way to disable them turning off when you turn on the blinker but i realize that may be a safety thing so that the blinker is more noticeable.
You would set drl drop out to no
Gibbs
GA
6.7L Cummins
@Ricks Ram, I checked the radio (UAS) at lunchtime and the soft key was there for auto-dimming mirror, so I should be good to go. I haven't driven it at night to confirm operation, but have no reason to think it won't work.
Ricks Ram
Yip you should be fine as long as you have an auto dim mirror.
Gibbs
GA
6.7L Cummins
Yes sir, I installed one last night that I bought from a member on here.
719c6
Where do ya adjust the TPMS threshold for a 2011?
OasisNinjaBat
