AlfaOBD
manny2308
Miami, Florida
Speaking of PINs, I just noticed this today. Maybe it's been there all along and not the right PIn but I had never noticed it before.. I already have my PIN but might be worth a try for someone that doesn't (or if someone can chime in that it's the correct PIN or not?)
Used it yesterday but no luck on my 2013 1500. Maybe something soon to come
manny2308
Miami, Florida
Added the remote start antenna after doing the keyless enter n go mod, what else do I need to get remote start working? I bought the remotes with the remote start button already.
1500ram12
5.9L Cummins
Do you have the proper hood latch? Or at least ground pin 11 on on the bcm c1? You should only have to program those remotes and if you go to post 1 in this thread and look for my name. I have instructions on how to program the remote start. It should be the same for you.
2018 Ram 2500 6.4L Hemi Tradesman
Noneck
2013 Ram 2500 Laramie. 35's 2 inch level. Raceme. Fully deleted 5 inch FlowPro Exh
Hey Fellas. So ive been chasing down getting the front heated seats to function in my 2013 2500 Laramie for 2 years now. I've tried several different heated seat modules including buying a brand new one that I had programmed by an aftermarket guy. After he programmed it my hard switches would not operate the seats but the soft ones on the radio would. He said there was an error in the steering wheel "improbable temp value" or similar. I'm just exchanged the module and will pick up the new one tomorrow which requires programming. I found this link today and offered the MX +OBD and will be getting alphaobd. I'm guessing I can program my new module myself with this correct? I am running a used module right now I got off eBay. My front seats will not heat but the hard and soft switches both show they are on. Cooled seats and heated steering wheel as well as rear heated seats work with this module and front heated seats worked with the other module,so it's a module issue not hardware as well as I can tell. I also have HID conversions in my factory projectors low beam which I plan to enable So I can remove the resisitor harness. Lastly I have a tuner on my truck for diesel deletes. This saves a copy of my stock tune and I have deleted tunes on the tuner and card, so I'm wondering if I can revert to these if I mess up? I've been reading thru this thread but it's a little lengthy lol! Any help would be greatly appreciated!
manny2308
Miami, Florida
No, that’s exactly what I wanted to know. Do you have any posts regarding grounding pin 11?
mtnrider
Georgia
.... Lastly I have a tuner on my truck for diesel deletes. This saves a copy of my stock tune and I have deleted tunes on the tuner and card, so I'm wondering if I can revert to these if I mess up? I've been reading thru this thread but it's a little lengthy lol! Any help would be greatly appreciated!
No. Alfa has nothing to do with the tuning/tuner and vice versa. There is no auto "recovery" file with Alfa. Need to make a baseline copy of you current configuration so you can manually step through it and try to get back if you mess up.
Noneck
Thanks. I should be able to program my new seat module with alpha correct?
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Any others near you?
You can always go the PIN puller app route, on Google Play store. The app is free, you do an in-app purchase for a credit to pull the PIN. $15 I think for the credit.
I got my PIN lol ... once I talked to the General Manager of the dealership he made it happen ....it's funny though how they service manager still wanted to charge me and I said nope .... but I got what I wanted and needed ...
1stindoor
NC
'23 2500 MegaCab
Stupid question here....I can't seem to get the alfaobd page to load. Where can I buy one?
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
I have an express, just bought the power folding mirrors, the modules and switches and the oem projector headlights with harness... so next week ill start bugging you guys about adding all the stuff like DRLs, puddle lights and so on
@Ramitiner did you get around to doing the mirror swap yet? I also need to add this to my 2018 Express to clear a narrow garage door opening. I know I need mirrors, modules and a door switch and was wondering if all the wiring was already in the doors for plug and play and then activate with Alfa?
1500ram12
5.9L Cummins
Google play store. The app seems to be the preferred option. There is a free version but only let's you look won't allow you to make changes. Other than that you'd have to click the link on their website to download the windows version. It can take up to 48-72 hour's to receive the license number to activate the windows version, he's in Europe and depending on how busy he is
Ricks Ram
If your truck currently has power windows and locks and power adjusted mirrors as almost all of them do then all the wiring is present. The extremely stripped trucks that have manual roll up windows and manual adjust mirrors so not have the wiring.
likes2build
Mohawk Valley, NY
2018 Express RCSB
3.6 Pentastar
Thanks @Ricks Ram , I was going to reach out to you but figured that you might be busy. I'm going to get the modules and switch (rcsb) from Benny @AllMoparParts.com and look for donor mirrors. How many wires in the white plug do I need to have?
Ricks Ram
The white plug is not for the power fold option. If the white plug has four wires it's an auto dim mirror. If the mirror has more than four wires in the white connector it's an auto dim, memory mirror. The power fold option will have a solid yellow wire and a solid blue wire next to each other in the black mirror connector. You might want to reach out to @STecoD. He has a perfect set of black textured non tow power fold driver and passenger auto dim mirrors with blinker,puddle lights he might be interested in selling. They came off of my truck.
1stindoor
NC
'23 2500 MegaCab
Thanks. Appreciate the quick response.
Ramitiner
U.S. ARMY VETERAN
NJ
negative, I have not, however if you do not currently have power folding mirrors then you will need those modules from behind the door panels and the drivers side window switch as well.
Ramsportrocks
east gabip
edit : see you tried it and it didnt work..
Devinmcdermand1
