AlfaOBD
chrisbh17
It will for most things...I used it for a while in my truck.
But when you need to connect to certain modules (when in Alfa, its the modules that have the wiring harness icon next to them), you'll need a wiring adapter to make the BAFX work, or you get the OBD MX and it works automatically by internally switching what pins of the OBDII connector it connects to.
If you have no need to connect to those other modules, the BAFX should be fine.
big daddys house
Hill Valley
OBDLink MX+ OBD2 Bluetooth Scanner for iPhone, Android, and Windows https://www.amazon.com/dp/B07JFRFJG6/ref=cm_sw_r_cp_api_i_1QeaFbQJAE42H
How you guys change anything if this gizmo says “no bi-directional” support? Do I need a security bypass wire?
2019 Ram 1500 Classic Tradesman 5.7
Like @crash68 mentioned, yes you will need to bypass harness.
This may also help with answering a lot of repeated questions we get in this forum.
Have fun modding brother!
Sent from my Pixel 4 using Tapatalk
NETim
Nebraska
5.7L
Okay! Thanks! I had the BAFX on hand, so that's what I've been using to add LED's and read fault codes. But nothing more.
Thanks!!
SR71RAM
USA
Yeah, pretty sure I was sent an RA3 instead of an RA4. Thanks everyone! It gives me the option to activate navigation, which of course it should already be activated. I also have no HD radio. Does anyone know if there is something that distinguishes an RA3 vs and RA4 in the model / part / serial number?
If you do not have an HD radio button you got an RA3. You can still activate NAV “relatively cheaply” through an ebay vendor. I chose that route because I had my RA3 already set up and SXM transferred over to the new radio.
Also YELP somewhat works too. Used it to find info on a restaurant while camping last year just to see if it could work. It did.
Dwight James
Can some one help me with my setup of the security bypass module for the 2018 ram 1500. This is my setup. The bypass security module has two plugs. Which goes where or do I only need to use one plug?
thanks
gapi
Georgia
HEMI 5.7
Well, (on the charger) I tried every NAV lockout related setting I could find and hit the security wall. Its a 2013 R/T and I'm hoping the security system is the same as with the trucks and can be defeated.
We used a OBDLing MX+ interface.
chrisbh17
Is there a label on the back of the unit? It will say vp3 or vp4.
Vp3=ra3 vp4=ra4
Otherwise you can check the system information screen for the hardware part number and post it here, we can cross reference from that.
Chino Valley, AZ USA
2019 Classic Crew Cab
thanks
You will need both plugs. There are two Block into which the wire will plug. The plugs are different, so you cannot plug the wires into the wrong Block.
I had to really search around to find the second Block on my 2019 Classic (it was facing forward and not readily visible).
Hope this helps.
RodeoGeorge
Dwight James
Hope this helps.
RodeoGeorge
Ok thank you.. will they both be on the front side by side or on the back?
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
My 18 ram1500 ...
See the green block and the white block.8fad4a84e449a0cb0216157d8fe5d512.jpg
M² Mods.
SR71RAM
USA
Thank you!
Vp3=ra3 vp4=ra4
Mpgrimm2
SC
5.7L
RLT1
FL
Hello
Is this thing on????
RLT1
FL
Anyone have any info on how to change the splash screen?
It’s been a while but you can change the splash screen with Alpha. I did it when I switched to the 8.4. There are several to chose from.
RLT1
FL
Found it.
EVIC Splash Screen (for Limited logo): (2015 to present trucks)
Vehicle Configuration 1: Special Package Select "Limited"
Vehicle Configuration 2: Special Package Select "Limited"
I selected Ram 1500 rather than limited.
Just remember proceed with caution.
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Can you add new wallpapers to the 8.4 radios?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Not without modifying the firmware files and getting the radio to flash your untrusted firmware.
