AlfaOBD
grantos68
Parkland county
you need to undo the led low beam setting and only enable "VehConfig 3: High Intensity Discharge Headlamps"
For some reason the LED setting still uses PWM to the lights and will not work
Right after I posted. I ended up leaving the led low beam enabled. And also turned on the high intensity discharge and they are working now. Thanks
So I just noticed now when I turn high beams on low beams turn off.
No Tyme
Bryan, Ohio
Select 2013-2018 (yes, even though you have a 19 classic)
Well, I must give you a big "Thank You" because I was able to make the change and after testing at 75 MPH, my speedo is dead on with my Garmin GPS and a GPS app I downloaded on my Android phone.
First I am not sure why but it seemed my truck was set at 2700 MM on the tire size. I did change it once on the road, got several dash lights and not being able to find the ABS as I stated above, I changed it back to 2700 and all the lights went away.
It was then with you help I found the two setting on my app as I set here at my desk but when I went and changed the tire size, from 2700 to 2650 I did not have to do anything else.
The truck has been started 3 or 4 times and as I stated I drove 75 on the freeway and the speedo is now dead on.
I will check for any code left in the truck and remove the by-pass harness before I go in for an oil change next week.
I must say I am proud of myself as I hesitated for a few months on doing this myself.
Thanks again.
Ricks Ram
Thanks again.
Make sure to tell your dealer not to flash your truck with any updates. If they flash your BCM all the changes you made will be erased.
Sent from my SM-G981U1 using Tapatalk
grantos68
Parkland county
Ok guys no I’m trying to change tire size. On 2015 sport. Trying to follow YouTube video. After I go clear faults then clearing rolls information it tells me it fails because I’m in active diagnostic session. I **** everything down service 4wd and trailer system would come up let it sit for a while. Then start truck up again service 4wd and trailer brake doesn’t come up anymore. But I have check engine light and used different scan tool says it’s u1412 implausible vehicle speed
2ARam
Georgia
I'm having an issue with Alfaobd on my pixel 3xl. I keep getting an error for "No internal nor external storage found. No data recording possible." I see where others had the same issue just couldn't find a solution. I messaged support for alfaobd about a week ago with no response. Anyone have a fix?
moldmaker70
Sevierville,TN
Can i turn off the TPMS all together with this? Mine is reading 102psi on one tire and then it will drop all the way to 0 psi as i drive over a distance so with that issue even by lowering the psi I think that it would turn that annoying yellow light back on as well as the "ding" that hapens intermittently. Thank you for any help.
SitKneelBend
St. Louis
3.6 Pentastar
Go to app permissions and make sure AlfaOBD has storage permissions.
grantos68
Parkland county
So I disabled led low beam, but I noticed now that when I turn high beams on the low beams turn off.
BEAST19
I would like to know the same thing ... can we turn off the tpms all together ? If so. , how. ?
Jimmy07
I don’t think anyone has done it, but if I were to try it, these are the changes I would make-
VehConfig 3 Base TPM system present- NO
VehConfig 3 premium tpm system present- NO
VehConfig 5 non regulated tire pressure information system- NO
VehConfig 7 TPMS configuration- SIGNAL NOT AVAILABLE
Then reset the rf hub
EDIT: first try VehConfig 7 TPMS configuration as- Logic 1 NHTSA Enable Warning
If that doesn’t do it, THEN try signal not available.
Jimmy07
I just tried, and can confirm this works. No TPMS screen, and no warnings:
VehConfig 7 TPMS configuration- Logic 1 NHTSA Enable Warning
grantos68
Parkland county
Try this, let me know if it works.
https://drive.google.com/file/d/1XDwyu2Y_Tm0afp6HAADA1FBJxhNLpbCY/view?usp=drivesdk
Sent from my Pixel 4 using Tapatalk
It worked the first time I followed it. Speedo is still out went to change it again. And after doing static ecu then clearing fault, then went into clearing roll. It gave me fault again then I had lights on power steering wouldn’t work. Did it bunch of more times got power steering 4wd back. Then had check engine light but after driving it like three times it went out. But Speedo still out truck is saying I’m going faster then gps. When you say key off is it quick switch or do need key for a minute every time for each step, or just the one?
BEAST19
What does reset the R.F hub mean and how do you do it ? Sorry I’m new to the whole Alfa obd thing.
javier_si04
san Jose, CA
Try every step
