Alternator Upgrade Needed
caltx01
Tyler, Texas
Pentastar
As a part of an audio system upgrade I have installed a Kicker CXA6605 600 watt 5 channel amplifier. I do not run the audio system extremely loud, just enough to get benefit from the sub-woofer and new speakers.
Should I consider upgrading my alternator or is the draw by this amplifier not enough to be concerned about? I don't want to start seeing batteries slowly degrade.
Thanks for any insight!
Cal in Texas
cam101
NC
The factory alternator will be good to run your set up. I have a system in my ram. I sm running more power than you. I have 2 amplifiers a 600 watt 4 channel and 1100 watt monoblock. If i start noticing anything. I will upgrade my battery. But you should be okay with factory.
Sent from my SM-G965U using Tapatalk
OC455
Central NY
Or check into a capacitor set up.
When I was into car audio, I had three of these in my 97 GMC:
I had multiple Amps and was pushing a ridiculous amount of power....
As others have mentioned, you don't need a larger alternator. You would be better served by adding a second battery and/or a capacitor set up mentioned above.
