Amsoil Conversion has begun
From Amsoil...
COMPATIBILITY
Synthetic Multi-Purpose Grease is compatible with many other types of greases. However, it is recommended that when changing greases, the equipment be cleaned of the old grease when possible or flushed with a liberal amount of Multi-Purpose Grease while the mechanism is in operation. Closely monitor the system for any inconsistencies. Grease compatibility questions should be referred to your AMSOIL representative or AMSOIL INC.
If you are gonna mix greases, you will want to check that spot repeatedly over the next couple weeks. Grease incompatibility is a rather large issue.
Quick_Shifter
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
From Amsoil...
COMPATIBILITY
I’ve only ever greased with this grease. So there is no mixing in this truck
RDixon
Ohio
RDixon
Ohio
Cool now I know who to hit up when I order Amsoil.
Quick_Shifter
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Figured after I did the plugs and belt I’d do a throttle body service too
Quick_Shifter
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Took just over 7 quarts. I let it all drain out. So now I will let it cool and check the cold level now that I checked the hot level. I drained it for about 3 hours. Just about 7.2 quarts to fill to perfection while trans temp was 180
Quick_Shifter
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Changing the spark plugs was 100% the hardest part of the entire job. Power steering fluid change was the second, transmission and coolant were tied for 3rd the brake fluid was satisfying to see all the Sediment flush out.
Hardracer
Swfl
2010 1500 laramie 4x4 crew cab
Dont forget the blinker fluid....i had too:signs8:
