Another Rubbing Question
NYRangerfan2
NJ
Hey Guys
Recently put on 295/60R20 Nitto Ridge Grapplers with 20x9 with a +18 offset.
I have some rubbing on something on the inside at full lock on both sides, so I have been avoiding full lock.
I have tried to do some reading and am not completely sure if spacers would help me at all here.
Also is there any real danger to this rubbing at full lock, could this cause the tire to pop over time?
Thanks
quietpeen
2021 TRX
Hellcat
where exactly is it rubbing? Are you leveled?
N
NYRangerfan2
NJ
Yep 2.5" level kit - When I lock my tires without moving I took a look and didn't see any rub but when I lock to back out of a tight space I can hear it, but do not know exactly where.
quietpeen
2021 TRX
Hellcat
look for a clean spot or a shiny spot. without knowing where it is rubbing i don't know if spacers would help or make it worse.
16WhiteQC
Hudson valley, NY
check the end of you sway bar as well at the end of the upper control arm.
Also, how bad is the rubbing? Is is a faint rubbing or aggressive?
Craig Hauser
Dallas, TX
that would be the size ridge grapplers I'm looking at getting. would love to see a pic if you have any.
N
NYRangerfan2
NJ
Not exactly sure what would be considered aggressive but it isn't exactly faint. I will check later today/tomorrow morning.
N
NYRangerfan2
NJ
Tried to take some pictures this morning at full lock but I was running late for work so they probably are not great / not what you guys need to tell. IMG_5706.jpg IMG_5705.jpg IMG_5707.jpg IMG_5704.jpg
N
NYRangerfan2
NJ
Do these help at all?
quietpeen
2021 TRX
Hellcat
when your are at full lock left do you hear the rubbing on the drivers side or passenger side?
I doesn't look like its rubbing the upper control arm. Could be the sway bar, but also could be rubbing on the fender liner
N
NYRangerfan2
NJ
The driver side, and I have had somebody turn the wheel with me on the outside of the truck while it is parked and it did not hit the fender at all.
quietpeen
2021 TRX
Hellcat
my guess is it is rubbing somewhere on the inside edge of the tire toward the cab.
No members online now.
Lurchav8r
