anyone have a new v-6 in 1500 overheating
teamwilson
3.6 pentstar
just bought an 2013 1500 quad cab and while driving home noticed that the temp gauge goes over to the 3/4 mark and then comes back down to the right of center took to the dealer and they said the fan was bad so replaced with new one temp still goes up the same and said it was normal the fan comes on at 230 and goes off at 213 just wondering if others do this or just mine because it has other issues i need to address. 230 degress seems to high but may be normal for these trucks thanks for your time and input.
emjohn4
Seems warm to me.
I saw a video of someone with a 2013 V6 doing a 0-60 type run, and the needle got up to roughly the 3/4 mark.
Does it only get warm when you're romping on it, or just driving normal?
Chewy
Bettendorf IA
V8
Could it be the louvers are closed behind the grill until a certain temp and then open causing the noticeable drop?
T
teamwilson
3.6 pentstar
usally goes up on normal acceleration and at idle driving at set speed does around 219-222 degress and yes i do think its the shutters at times but you would think they would open alittle sooner. thanks for the feed back
przemek
Penstar 3.6
Yup same here, took mine to the dealer, they are in the process of flushing it out completely and replacing the thermostat. temp going up like that on the 3.6 is not normal. my dads journey with 3.6 never touches half way always a hair below.
Burla
2010 Hemi Reg Cab 4x4
If you are not in snow country you don't need anti freeze as much. usually your anti freeze versus distilled water is 50/50. You can run the mix down to 20% anti freeze 80% DW and run 8 ounces of RMI 25, and your truck will run considerably cooler. I wouldn't trust anyone to do this except myself, that is the only way you would know it is distilled water going in the radiator. Hose water is no good for the radiator, if you want to avoid rust. You could empty a gallon or two of your current anti freeze and replace it with distilled water, that also will make a difference.
Abraham1989
Norwalk
I have same issue but I check mi temp whit a laser thermometer the temp gauge on the truck is 3/4 but on the laser thermometer shows 195 goes up to 200 then return fan kick in an lower the temp to 190 an stay on 190s to 200 and the cluster show 210 to 230 I just going to instal a coolant gauge it supposed to be a software re flash but I don’t have the money to do it at the dealership
Abraham1989
Norwalk
There’s a video I recorded
Abraham1989
Norwalk
The shutters are not the problem is a software update a re flash
Abraham1989
Norwalk
WTM75
Upstate NY
3.6 Pentastar
The temp on my ‘17 stays between 190-200*F. At least that is what the gauge says.
GrumpyOleMan
South Dakota
Just towed 6600# with my Pentastar this weekend. 75 degrees +/- outside up and over rolling hills for 600 miles and temp gauge never went over 212. FWIW
leeb1212
Alabama
My 2013 quad cab slt 1500 had been going up to the 3/4 mark also...but now will overheat and heater does not work...have replaced new water pump.thermostat...intake gaskets and still overheating and fan is loud win at 3/4 mark
crazykid1994
It seems like your fan is only going on for overheat. Could be a bad low speed relay or bad temp sensor on the fan shroud. Computer controls fan speed so there’s most likely something the computer isn’t seeing that it needs or a part has failed
grizzstang
Calgary, Alberta Canada
The 3.6 can be a PITA to get all the air out of the system.
I would also take a close look at your rad since your truck is a 2013 with likely a lot of miles.
southalum
