Anyone install cargo tie downs in their bed?
808ram1500
Big Island, Hawaii
4.7L
Thinking of adding some cargo tie down rings located on 4 corners of my truck bed. Any recommendations of brand and type? Bolted or weld to the bed?
quietpeen
2021 TRX
Hellcat
Your truck doesn't have die downs in each corner already?
ramportin1
Sickest member here
Oregon
I added 3,000lb D-rings in the front/center of my bed for better strapping down multiple dirtbikes at once. Definitely i would bolt rather then weld as you want some kind of backing plate to disperse the stress off one small section of your thin bed metal.
billyw
Northwest
I stretched a length of plastic coated chain between the front and rear tiedowns and now can latch onto it at any location I want.
sandawilliams
Pueblo West, Co.
6.4 hemi
808ram1500
Big Island, Hawaii
4.7L
I have the ones on the floor of the bed. I want to add some on the middle of the bed wall near all 4 corners so I can strap things Luke coolers, 5 gallon water jugs etc when I go camping.
808ram1500
Big Island, Hawaii
4.7L
I was thinking this too, but isn't getting behind the bed a PITA for the backing plate? Unless I take off the bed that is.
ramportin1
Sickest member here
Oregon
That would be a PITA for sure lol, i meant to say front/center on the floor of my bed*
BWL
Embrace the skeptisism
BC Canada
I did a wood floor with aluminum box liner on one of my trucks and bolted D-Rings through the plywood I lined the nuts up centered between the ridges and they were surprisingly strong. I went treated plywood floor because the rubber mat kept warping from diesel.
BWL
BC Canada
I welded these up for my current truck. They provide 4 solid tie down down low as well as solid rails in the bed to tie to. The skeleton the fender well so they don't really cost any bed space.IMG_20171126_120427.jpg
Docpaulo
Remove your rear wheel liners...its easy to do...
you can reach in there to put a backing plate... if you tie down anything serious, use a backing plate
808ram1500
Big Island, Hawaii
4.7L
Thanks for the reply guys. The backing plate thing is what I was searching for. I have a bunch of stainless U bolts from home depot. Looks like having that backing plate makes all the difference in support.
Peter Albert
Bellflower
3.6L V-6
grizzstang
Calgary, Alberta Canada
^^^ I had Bull Rings on my last truck (F150) and used these to strap in my quad, a Yamaha Grizzly 700. I thought they worked great.
They do move around a little in the stake pockets but they certainly never felt like they would come out and strapped my quad down tight.
Gr8bawana
6.7 CTD
Has anyone figured out how to put a tie-down of some kind in the center of the bed rails?
