chrisbh17
- Oct 12, 2017
- 6,691
- 7,475
- 2017
- Hemi 5.7
I'll pile on here. I finally got an error by turning OFF LED low beams (because I have HID enabled and HIDs installed). This caused me to receive a "low beam bulb out" error when turning on high beams. I didn't receive this error when I had actual LED lows installed.
Originally had factory Quads. Currently have G2s. Seems there is an error code slider that sums multiple inputs before triggering.
It would be awesome if there was a way to know just WTF the BCM is doing inside its black box
Im pretty sure we know its looking for resistance, because adding load resistors "fixes" stuff. But it would be nice to know just how MUCH resistance its expecting, so we dont need to use any more than necessary.
Would also be nice to know if the LED present settings change how much resistance its looking for, or if it stops looking for resistance altogether.
Ever since I went to 12.2V for all voltages (except low and high beam which are 14/14.2) Ive gotten far less random errors. Ive also noticed the errors act "differently". If Im connected to the BCM then disconnect without clearing any turn signal errors, the next time I use the signals the errors will pop up. But just that once....I wont see them again until after I connect/disconnect from the BCM. TBH I think its SUPPOSED to work like that...kinda like a reminder that you forgot to clear codes.
