Had to take these off my truck last January because the white/amber of the Profile RGB strips were not bright enough. So I removed them in January and finally just got around to opening them back up and adding Profile Sequential Strips in the upper + lower DRL sections. Also had to remove the tint over the DRL sections as that was also causing the output to be super low.
These pics are from when I originally built them last fall, I haven’t resealed them yet without the tint and with the new strips added, but here they are.
AlphaRex 2019 Style custom build. Close to $2,000 into this retrofit and that’s without shop labor (did it all myself), strictly parts. All 4 projectors were replaced with Morimoto Mini D2S projectors, 4 Morimoto D2S HID kits, 4 profile demon eyes, 4 profile rgbwa strips, 4 profile sequential strips, Morimoto Bluetooth controller, tons of custom wiring, without a single butt connector or solder, all done with 9006 plugs, or JST plugs. All wiring is as professional looking as possible without any cut wires or connections. Projectors are mounted with custom brackets, as the setup inside these lights was not very friendly for projector retrofits.
