Anyone try Modifystreet headlights?
1500ram12
5.9L Cummins
Hey I have projectors on my 2015 sport and changed bulbs to those sylvania zxe and still suck for seeing the road especially in the rain. So you might want to consider keeping the quads if you drive alot of dark roads especially hwy. I had quads in my 2012 with the zxe bulbs and those quads were 1000% better to see the roads. I missed a few dear with those quads. My projectors don't do much of anything. I'm currently looking into led or possibly hid change as we speak lol. A friend had led plug and play bulbs and seemed to work so much better than mine in his projectors
How light is projected through the 2 different style headlights if different. A projector gives you a more defined beam pattern compared to a reflector style housing. It is an adjustment getting used to a cut-off line compared to the quads where it just fades. I would definitely recommend upgrading your bulbs either to hid or led's. A few cheaper but great choices that a bunch of us use with these headlights are,
HID- Innovited 35w (~$40 Amazon)
LED- Hikari Ultra (~$80 Amazon)
. Katana (~$50 Amazon)
Auree (~$60 Amazon)
The katanas are believed to be the actual manufacturer's of the supernova v4's ($200+). The visually appear identical, right down to the wiring.
I found the Auree led's to be slightly brighter than the katanas. I sold my Hikaris before I had a chance to test them.
2018 Ram 2500 6.4L Hemi Tradesman
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Auree (~$60 Amazon)
To pile on, it's also much more important (in my opinion) that the projectors get aimed property. Poor aim isn't as noticeable (as the driver) with reflector housings due to more light scattering but with projectors the cutoff can leave you feeling night blind if it's not raised high enough.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Jordanp
U.S
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
This is what I got , would link to amazon but of course they removed it right after I bought it .
Ah, you got HIDs not LEDs. Does the plug allow you to flip the + and - plugs?
Jordanp
U.S
Yea the plug to the bulb itself I can change the positive and negatives , u want me to flip flop the one that isn’t working around other way ?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Yes
Jordanp
U.S
Forgot to post this here i originally posted in the alfaobd but should of done it here .
Ok I found the issue , in tracing the wiring found a black wire that was pulled down in the connector housing just enough to not get a good connection
Pushed tight and taped ends . Flickered for a minute when started truck but seems to have stabilized . Hopefully will last but have the other hid coming as a backup . Thanks for all the help
Jordanp
U.S
Anyone have any recommendations on fog lights to go with this alpharex headlight ?
Thanks
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Jordanp
U.S
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Out of stock till February grr lol , also these show h11 my fog lights when I look them up are 9145 isn’t that h10?
Sorry I’m a newb to all this so maybe h11 will work also
Sorry, I should have specified. You want 9006.
Jordanp
U.S
Isn’t the 9006 for projector headlights ?
My truck factory is w/o so when I look it up says 9145 .
Sorry I’m confused on this
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Do you have vertical reflector fog lights? If so, this 9006 bulb fits without modification, is brighter and is not blinding to other drivers.
Jordanp
U.S
Not sure I’ll have to look into the veritcal , just know when I do a automotive bulb lookup for my truck it comes up with 9145 as the fog light .
If it will work fine glad to order just didn’t want to order the wrong one.
Hikari doesn’t show any 9145/h10 bulbs only h11 or the 9006
Other bulbs say direct replacement is a h11 for my truck so this is why I’m so confused
Jordanp
U.S
Think mine are vertical looks like they stopped horizontal in 2013
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Correct and 9145 is the stock bulb. 9006 is an "upgrade"...
noraa73
