BEAST19
- Mar 26, 2017
- 1,067
- 742
- 2015
- Hemi 5.7
Hahaha. Not under inflated just running aftermarket rims and tires with no sensors lol I’m trying to maintain mpg above 12mpg lol winter gas blowS!!!You're golden, except you're running 73mph on an underinflated tire!
I eventually made it up to 204 oil temp ......I have a vented custom hood so it cools pretty wellMy oil temp usually runs ~5° warmer than the coolant.
Don’t u want oil temps to go above 200 for purpose of burning off contaminant etc? Not to knowledgeable on the topic just going off some stuff I’ve read on hereMy oil temps don’t go above 186 on redline 5W30 but I also run a 180 T Stat and deleted my clutch fan
Water methonal injection basically steams the engine clean where I don’t have to worry much about contaminate.Don’t u want oil temps to go above 200 for purpose of burning off contaminant etc? Not to knowledgeable on the topic just going off some stuff I’ve read on here
Oil you want above 200*F. I personally like a 210*F and it’s to allow water and condensation to evaporate out of the oil. 210-220 is nothing for modern full synthetic oils as they are just starting to warm up.
Water **** does nothing for oil in the crankcase or Engine for that matter. Water **** does steam clean the combustion chamber/valves and manifold/header primaries.
Researched a number of racing/engine building sites, and a consensus for an ideal oil temperature range for a motor not on a race track was between 180 and 210 F. Even with oil temperatures in the mid 180's, moisture will evaporate out, just not as quickly as they would at higher temperatures. Those sites also clearly stated that consistent oil temperatures over 220 degrees will have adverse long term wear issues on any engine; more serious issues if oil temperatures are consistently higher, as in the 230's to 240's or above.
The oil in my truck, on a highway run settles in between 199 and 203 during the summer months, and in the 195 range when it's cold. Around town the oil temp gets to 184 or so during the winter. I'm also running a 180 T-stat.
Water **** also substantially lowers combustion temperatures which keeps oil temps and coolant temps down yes it may not clean the crank or help with evaporation but ideal temps are between 180 and 210. I prefer the lower temps as the Engine will last way longer under boost than at oil temps of 200+
