- Jan 17, 2016
- 23,727
- 54,500
- 14 Sport
- 5.7
If you were working on it yourself,i'd say pull the injectors and do a home clean on them,and blow out the fuel rails,but if it's being done under warrenty,let them carry on,eventually you might end up with a new engineOk... the saga continues...
New PCM in...still has a misfire in cylinders 2 and 7. I was told they are eating the cost of the PCM since it didn't work. Compression is still fine, everything tests ok otherwise.
Next test is going to be the fuel injectors. Swap injectors on cylinders 2 and 7 with others, reset codes and see if the misfire moves. (At least they said the Star techs are helping them now as to the diagnostic steps.)
If fuel injectors are working properly and misfires don't move, the next step is to open the engine and look for internal issues (cylinders, springs, lifters, camshaft).
Regarding taking the truck someplace else, I was advised that doing so would require them staying over again and starting with Star techs from scratch. Is that true? This is all covered under warranty, so nothing out of pocket for me. But I just want the truck fixed!
Questions for the group...
1. Could the fuel rails themselves be clogged or damaged?
2. What is the path the fuel goes when entering the rails? I thought i read somewhere that it enters passenger side at 8, goes up the rail to 2, then crosses over to the driver's side at 1, then down that rail to 7. Is that true? If so, could it be a coincidence that the two problem cylinders are at the end of the fuel paths on the rails? I'm spitballing here (if my information is accurate).
3. Someone told me that the fuel rails are metallic and coated internally and if a piece of that coating broke off, it could be causing a problem like a blockage. Is that even possible?
Thanks again.
Joe
Injector cleaning
Supposed to go cold and snow for the next 10 days,so i figured it was a good time to pull the injectors and give them a cleaning.Got them soaking in injector cleaner,where i'll probably leave them for a couple days before using some carb and choke cleaner to wash them out using my old homemade...
