Back up lights
ramhunter9
P-Star Jeep Wrangler
I have some back up lights coming for the rear bumper ... Is there a way to tap them into the OEM light on the bumper so they come on when in reverse ? If so what is the way of doing this .
badfish888
Va beach
2012 hemi express
ive always wanted to do that, ive always just used a toggle switch, but that seems way more convienient
txbass06
NE Texas
5.9 Magnum
All you've got to do is use a wire tap on the power wire from the lights you're adding to tie into the power wire running to your reverse light socket in your tail lights
Sent from my iPhone 4 using Tapatalk
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
yeah.....
If memory serves me right the wire is white? I'll have to look for the wiring diagram later tonight.
RubberFrog
Do NOT tap the reverse on the tail lights unless you plan on running a relay to power your new lights. You have the tow package, correct? Tap into the reverse wire at the hitch plug. And still use a relay!
BMRbrnSNRbrd
Norman, OK
2010 Dodge Ram 1500 CC Hemi Sport
Good call by George. Defnitely use the hitch wire.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
purple? :D
ramhunter9
ramhunter9
I have the round and the flat .. thanks guys
BigHorn777
Wisconsin
I did the back up lights on mine only I mounted them to the leaf springs. I know sounds weird but they actually work really well and light up the area behind the truck a lot. I back my truck into my garage so I need to see where I am going when it's dark. The lights were cheap too, I got them from Harbor freight. I tapped into the back up wire from the trailer connection and used a relay also. Here are a few photo's, please understand these have seen Wisconsin winter so they are getting a little rusty but they still light my way.
Photo link: http://craigsgarage.shutterfly.com/pictures/233
ramhunter9
ramhunter9
I just ran them to a switch. Ran a fuse Ect. Just need the ups man to show up. I don't need them for backing up. More for hunting.
