Bed Management
McBroom
Denison Tx
Hemi 6.4L
Maligator
Hem 5.7
Found this hack on another forum, and I went out and bought 2 Husky bins from Home Depot and a racheting cargo bar to keep them there. Cost was $40 and with a tonneau cover on, it's like having a small trunk in the back of your bed! And you can remove the bins and the bar in seconds if needed.
Cargo Bins
https://www.homedepot.com/p/Husky-Stackable-Storage-Bin-in-Black-232387/300170479
Cargo Bar
https://www.homedepot.com/p/Keeper-Ratcheting-Cargo-Bar-47059/207097432
Totally stole your idea today, put my $50 home Depot gift card to usefcd57adb298ed3ca85e2c9a7eec16fc3.jpg
atech
Ontario
I use plastic laundry baskets with bungee cords. Cheap and stackable. Also have 1/4" all-thread bent at one end for hooking suit cases or baskets.
TigreST
Canada
42de5333-2547-4ebf-a3a1-3aa1147d2aae-jpeg.169684
5c1f2490-bc6c-4025-9122-05903658cadf-jpeg.169685
Re Post:
2018 RAM Sport, 5’7” box with spray on factory bed liner. My board is 67” long and looks like 2x8 but measures out to 2x7 (go figure). If I had to do it over again I’d go 67 1/16” or 67 1/8” to get a snug/ tighter fit to the box sides. That said I do not hear the board banging around while I drive and it’s easy to lift out. I contoured the lower corners to fit the box contours, but forget what I used as a template for the radius,...maybe the lid off a paint can or something similar ? No rocket science used in the production of this thing at all.
HTH, YMWV,
T.
shrubs2000
oHIo
Cargo Bins
Cargo Bar
I did the same today.
Ready Freddy
Atlanta North
Cargo Bins
Cargo Bar
This is genius! Exactly the solution I have been looking for! Great find!
Ready Freddy
Atlanta North
Cargo Bins
Cargo Bar
Just back from Home Depot with the bins and bar. Fits like a glove.
I don't know how to do it, but someone should repost to "Best Ideas Under $100"
michael harpe
U.S. Army 2001-2014
quitman, ga
2018 Power Wagon
6.4 hemi
Posted it for you :)
Sent from an undisclosed location in Iraq
POINTMAN380
Rogers, AR
Cargo Bins
Cargo Bar
Dooood.....this is the best $40.00 I've ever spent on a truck. Thanks for posting this.
hodge-xj
5.9 cummins
I need a tonneau cover and this is happening!
TigreST
Canada
FYI: the 2x8 I pictured above works great for little cost and a bit of crafting, but...... Beware! The Crew Cab box is wider than it is long. My cargo board will not fit in the box from front to rear with the tailgate closed ( missed it by that much > < ) unless I angle it some degrees across the box in a diagonal fashion.
PSA Complete: We now return you to your regular network broadcast.
T.
Pull Ya
Cedar Creek, Tx
Sorry--went a stray for a minute-
Jay
TigreST
Canada
Never mind.
T.
Pull Ya
Cedar Creek, Tx
I saw the admonishment from the mod's on an earlier post after I posted my misguided post so I had to change it. CYA
Jay
OC455
Central NY
I was going to put in a suggestion but it got a bit saucy.... :p:D
festivus15
USA
I cut a piece of 2x8 lumber to fit in the slots on sides of bed. Works perfectly for groceries, snow brush, washer fluid jugs, etc. Cheap and easily removed if needed all the bed.
I did the same. Except with a 2x10. Only part I don’t like is that I cut it a tad short so it rattles a little while I drive.
Mike Flea
US ARMY VETERAN
Streamwood, IL
Already been mentioned, but, I use a 4' bungee, milk crates and a cooler or 2, and run the bungee through the handles. Coolers are a necessity if picking up frozen food or refrigerated items.
TigreST
Canada
Don’t stop for a few beers on the way home...and ditch the coolers!
T.
Fpye
