Bed noise
BuddyF62
3.0L Ecodiesel
I'm hearing a squeaky noise when driving. It seems to be coming from under the bed on the driver's side. Happens when driving on any road or turning in either direction. Can't figure out what is going on.
B
BuddyF62
3.0L Ecodiesel
I'm new at this forum stuff. The issue I'm having is with my 2021 crew cab bighorn ecodiesel
Travelin Ram
If you can replicate it parked, for example by jumping up and down in the bed or bumper, then get someone to assist in hunting it down.
Option 2, begin by spraying suspect items with WD-40 and seeing if the noise disappears. Leave plenty of time for it to penetrate and check that spot before moving on to the next. Takes time, but you’ll find it in the end.
B
BuddyF62
3.0L Ecodiesel
Thanks. I've already tried replicating the noise when parked, with no luck. Only makes the noise when moving. But, I think I'll try your option #2 and see if that works. Once again, thanks
gtomike60
Milford,Mass
5.7L HEMI
Does the squeaking change with vehicle speed or engine rpms?
Or is it when the suspension moves from bumps or surface irregularities?
Buddy this must be the thread you're referring to,took me a minute to find it.Not sure why you're messaging me on it though,lol.I'd follow the reconmendations given above with spraying things down with WD40 to see if you can isolate the noise.
