Been charging for 30 minutes trinity t-1000 and it still says need to charge
sarvj
Been charging trinity t-1000 for 30 min still saying to charge so I can use I'm charging with the usb cable that came with it off the computer am I doing anything wrong ?
WadXpress
HEMI
I dont think it holds a charge.Just plug it in to the truck if you need to use it
EDIT POST 666
DILLIGAF
Canadian Forces
Canada
It only works when it plugged in.
Paluby
Alaska
What's been said, it doesn't hold a charge and you won't be able to flip through the performance pages while plugged into the computer. Has to be plugged into the truck.
charonblk07
Calgary, Ab
F1-A forged 349ci
If it's saying low voltage or charge required when plugged into the truck's OBD II it's the truck that needs a charge, not the Trinity. The Trinity is very voltage sensitive so if the truck battery is low it prevents writing to the truck to potentially prevent bricking the PCM.
