Behind Grill LED Pods Installed
Galion
Edmonton, AB
Since my truck is in the dealer's bodyshop for a few days and I'm bored without it, thought I'd show my LED's I installed a couple weeks ago:
How they look behind the grill
The end result
Birddog
West Palm Beach, FL
2016 Bright White 3500 Laramie 4X4 Long Bed
6.7 Cummins TD, 3.73
Wow they look really good behind the grill. I have pods next to my tow hooks. How well does the light get out?
chuck
Maryland
2013 True Blue Big Horn
Lookin' good! I have the same question as birddog
Galion
Galion
Edmonton, AB
Actually the grill blocks very little light, I plan on getting another set of them with flood lenses to go beside these ones since they're spot pattern lights.
blackbetty14
CT
Hemi 5.7 VVT/Etorque
Doesn't look bad at all. Would love some output shots on a dark road or parking lot before and after the pods are on.
I would think a longer 20" light bar would fit the grills design better… esp when lit. But I always thought the grill would block a lot of light.
chuck
Maryland
Yea looks like they throw a pretty good amount of light. My headlights are basically worthless. I looked into getting an LED strip to mount across the front. Tossed that idea once i realized how damn expensive those LED strips are haha.
Jarhead57
Santa Barbara, Ca
2015 4x4 CC Bighorn
Here is a 20" in there....works very well...
Galion
Galion
Edmonton, AB
I'll have to take some pictures when I get my truck back, I did consider putting a 20" in but decided not to since I thought the bar in the middle would block too much to be worth it. This setup only cost $100 all in, so once I get another set of floods it'll only have cost $180.
chuck
Maryland
That's not bad at all. I'd say well worth the price.
That set up jarhead is running looks great too.
Iczer
2014 Dodge Ram Black Express
I wonder if this is possible with a 2014 and the active shutters?
dbrock34
Can any of these lights be ran with the low beams or are they all high beam only?
dmullen
HEMI 5.7
Looks great behind the grill.
What are you guys using for the 20" light bar and how was the installation? Did you have to customize brackets to mount it?
TRXHemi
Sugar Land, TX
I did a 20" behind the grill and removed the active shutters... I did leave the active shutter motor connected, but I was still getting a CEL for it.
So I put the active shutters back in, and removed the 20" LED behind the grill.
Here is a pic though....
lokal907ryder
wasilla, AK
I did a 20" behind the grill abd removed the active shutters... I did leave the active shutter motor connected, but I was still getting a CEL for it.
ive been wanting to do this as well. theres got to be a way to take the grill shutters out. I wonder if the dealer could disable that function in the ECM?
Valth
Odessa, TX
I used the brackets and everything my bar came with, no altering anything. I just measured and drilled two holes for mounting on the brace in front of the radiator, left bolt was kinda hard to install cause there's no room, took about a hour.
Jarhead57
Santa Barbara, Ca
2015 4x4 CC Bighorn
You can just drill holes and mount it to the bar in front of radiator, I made some brackets so as to put the bar as close to the grill as possible.
TRXHemi
Sugar Land, TX
This is easily done without the Active Shutter crap in the way!! When I had mine removed, my truck actually ran cooler.....
Reticle918
