Belltech Question.
5.7Ram
2011CC
So i order the 2/4 drop from Belltach , 4 coils / 4 Performance shocks.
Has anyone cut a coil off the springs on this kit? Does anyone know if there is enough shock travel in the performance shock if i cut the springs? I would like to get close to a 3/5 if possible.
jojo750
south carolina
v6
somebody did it with the mcgaughy kit, and got a 3/5 drop.
edit:http://www.ramforum.com/f39/2010-ram-1500-2-5-drop-11191/
whooops. he had cut stock springs in front (2"drop), then cut the mcg 4" drop spring in the rear (for a 5" drop).
think he kept the stock shocks though.
if you get the BT shocks, those are lowered shocks, so you should be able to cut a little off the spring and be ok.
i run the BT street perf shock in the rear of my truck. and there is room to move with them.
quietpeen
2021 TRX
Hellcat
good to see more lowered 4th gens
5.7Ram
5.7Ram
2011CC
thanks , i want to go low! but iam still debating if i should go 22' with fat tires or 24' with middle size tires
