Sand and dry, sand and dry, sand and dry till your happy (to see what areas you need to focus more on)
The less little clear dots the better it'll look
For the little effort it requires to take them off I would
It'll be easier to sand
check out my thread on your tails...
http://www.ramforum.com/f76/how_tint_your_tails_using_rattle_cans-3232/
BTW where in tx are you, i might could help you with your lights
well for rattle can clear coat i dont suggest anything but duplicolor, ive tried others and none are good unless you buy the $30 cans sold at auto paint supplies stores, in my write up i used heavy coats, then after you let the clear cure (i suggest 24 hours) you wet sand with 2000, and after you get them 100% smooth hit them with a rubbing compound/ polish, if you have access to a buffer its much easier
this is what mine look like after a sand and polish:
here are some others ive done using the same method:
it works with colors too lol:
Did you just try polishing them by hand once?
Keep polishing lol
Depends on how well you sanded haha
Polishig should shine them up
