Ron Basile
The cheapest ones on Amazon. I rarely use the wipers with rain-x....
this is the biggest crock of smack!
i have run rain-x washer fulid in my vehicles for at least 10 yrs and never have i had a washer sensor failure. RAM, Toyota, BMW, Jeep.
whom ever reported the above thread probably never ran their washers and the fluid gunked up.
If I'm not mistaken, it doesn't clog up anything or go bad. It has to do with the way the newer sensors collect information. Apparently the Rain X fluids and the ingredients coat the sensor over time causing it to get bad readings. I think cleaning the sensor causes it to work properly again.I can't argue with your success. I'm only reporting what has been stated by several owners on various forums. I'm no Rain-X expert but I believe the culprit was reported to be their orange fluid. Can't be sure, going by memory.
Correct!If I'm not mistaken, it doesn't clog up anything or go bad. It has to do with the way the newer sensors collect information. Apparently the Rain X fluids and the ingredients coat the sensor over time causing it to get bad readings. I think cleaning the sensor causes it to work properly again.
I have the same problem. They worked great in Texas. I moved to Colorado and they’re streaking. I’ve got a 2012 Ram 1500 Texas Edition with 63,000 miles. I just put the Bosch wipers on a year ago, or 3000 miles ago. (Off-topic. Crazy fact. The Hemi tick lessened once I got to Colorado)Got Bosch Icons on mine and they're just okay...Started to streak at about 20,000 miles (8 months in or so). $50 for a pair you'd figure they're top notch. Either I'm unlucky or the Colorado weather beat them senseless.
I’ve been using Trico Neoforms for years! StArted with them on my Tacoma! I always got good use of them! Replaced every spring and fall!
Salty road spray all winter, lots of mud in the summer!
Never had a failure as far as them coming apart! Always held to the glass well...minimal streaming, even with heavy mud and ice!
Still haven’t had any reason to try anything else!
Can't believe a post on Wiper Blades has become 3 pages long. Lot's of interest and good suggestions
I use Trico Ice, they last me a year which is about 25K of snow and ice then heat, sun and humidity. And my poor vehicles sit outside all year.
