Bilstein 6112s with 4" Superlift
DILLIGAF
DILLIGAF
Canada
Those UCA's look like they are on the correct side judging my the abs line hooking in the correct locations.
Go look at the pictures on the mevotech website. the nubs are forward.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
The zerg fitting doesn't dictate your control arm from left to right installation. The arms may have a stamp for L and R but your initial installation was correct.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
To much angles on the CV axles and UCA. and would need stupid spring spacers in the rear as well.
The 6" crossmember drop brackets plus diff bracket will keep your cv axle alignment and lift.
smoothee
St. John's, NL
No stamp on them. Got mine from RockAuto, installed them according to the part #'s on the boxes/bags. Found it strange when the fitting was on the front side so then I double checked the website to confirm I had the correct sides and came across the install of a couple of other people, who had them installed the same.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
I looked at those pictures. Something isn't right there. Every UCA I've seen installed or installed myself has that abs, wheel speed sensor mounting on back side for correct alignment cycle of the suspension. Bet you get a really rough ride blowing out the ball joints.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Show me where. I'm having a hard time wrapping my head around your lift troubles and his soon to be if you both have the same problem.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Simple enough. Match up the angles of your known stock control arms to your installed ones. Is there a variance? Pics?
smoothee
St. John's, NL
I can keep going but anyway...and I had ride troubles long before replacing ball joints btw
smoothee
St. John's, NL
And they had no issues performing an alignment, my UCA's are perfectly flat
DILLIGAF
DILLIGAF
Canada
That nipple is for the factory installed air ride.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
It's the angle of the arm as the suspension cycles not just the fact that your ball joints are flat. Flat ball joints are not the only criteria for installation. I'm surprised they didn't provide instructions
RedSRT4Me
Scottsdale, Az
2015 CC Sport
I see how what your saying on the nipple. Too many nipples to tell. So that piece on airsuspenion must be where the sensor determines ride height.
But both of you are running coil spring suspension. Most manufacturers will specify for air or coil. Most of the time they don't mix.
At least now you know for sure they are installed right :cool:
DILLIGAF
DILLIGAF
Canada
These ride great so far. Glad I got rid of those Rancho quick *****...lol..
DILLIGAF
DILLIGAF
Canada
Well With the alignment done Im 44 " in the rear and 42 1/2 in the front. with those 6112s at 0.8
Pretty sure once I need an aligment again next year ill set them to 1.2.
UCA is perfectly level and my CV Axle is also almost perfect.
DILLIGAF
DILLIGAF
Canada
Getting my trucks yearly alignment next week, So its time to set those bills at 1.2
im Now 46" and 44.5" due to the bigger tires. There was zero settling on those 6112's after a year.
Hopefully at 1.2 ill be close to 1.5" of rake
