Curious to see the stance, I have my 6112’s set @ 0.8” with my 4” Superlift.
I could be wrong and it's hard to tell from the pics, but it looks like your upper control arms might be on the wrong sides too. Just something to check so you don't possibly have to tear it apart a third time lol. I'm just going by that little threaded nipple looking thing on the arm itself.
Lol yeah I only knew that because I installed these a few weeks ago and thought the same thing. I guess that would've made too much sense, so just had to zip tie the wire. Apparently the newer style oem ucas have the nipples on the front like the Mevotechs so not sure what the purpose of them are...You're right... I figured that nipple was to zip tie my wheel hub sensor wire to...lol... Just checked the Mevotech Website and those nipples point forward ... *** ... thats useless.
Haha I hear ya man. Luckily they didn't have that genius idea until the year after I bought mine lolMOPAR and making sense should never be used together... hahahaahah.. like why they welded the ring gear inside the housing on the gen 4 diffs... lol... I guess saving 35 cents on bolts was worth it to them.
Looks like **** at 2.8 :-( im also 2 inches Higher than the rear. The CV angles and the UCA are bad as well.
I guess I will be taking back apart tommorow and setting them to 0.8.... LOL..
View attachment 465054View attachment 465055
PICNIC, sorryI could be wrong and it's hard to tell from the pics, but it looks like your upper control arms might be on the wrong sides too. Just something to check so you don't possibly have to tear it apart a third time lol. I'm just going by that little threaded nipple looking thing on the arm itself.
Well I guess I quoted the wrong member the first time!What is the height of your front fender with them set at .8 ? compared to the rear ? Did it give you any rake ? I want to be as level as possible without having to use rear spring spacers .
Dont really want to do this again... *****
If you got the superlift drop brackets you could leave it at 2.8
@DILLIGAF
Guess I have more rake than I thought, but it sure doesn’t look like much to me.
front measures 42” on both sides
Rear driver is 43 1/4”
Rear passenger is 43 5/8”
I’ve got a smidge over a 1/2 tank of fuel.
