Bilstein / cv axle help
countrygunner
Ok guys I need some help. I recently put bilstein 5100's on my truck set at 2.1". They look great and ride great. However I've been getting a little chatter or tick or rub in my gas pedal. It feels like it's on the driver side.
It's not a steady vibration like a tire out of balance. It's more like tick, tick,,......,tick and so on. Very random and doesn't do it all the time. So I got to checking myself. So I'd know where to point the guys at dodge to repair it.
Today after taking off the wheel I checked for wheel bearing play and there was none. Checked all the sway links, tie rods, and ball joints. When I spun the wheel I could hear a little rubbing sound in the cv axle right up against the diff.
This truck has only 32000 miles. I pulled and yanked on the cv axles to see if I could isolate the sound but both sides seemed the same except for when I spun the wheel and got that rubbing noise. It just did it like for a split second once every rotation.
Could the damn cv axle be bad? Could it be the intermediate shaft bearing? Could the bilstein lift have caused it?
Eline24lenny
2o12
5.7L
Where the cv axle goes into the diff there is a clip that prevents it from having any play back and fourth I'm almost positive that's the problem
Sent from my SAMSUNG-SGH-I337 using Tapatalk
C
countrygunner
What so you think the drivers side may be on too far. Causing it to possibly rub against the diff seal or maybe just migrate back and forth causing a vibration
Eline24lenny
2o12
5.7L
Yes
