Boss Plow
nweselovs
USA
I am installing Plow in 21 Bighorn. I will assume I remove air dam and install plow frame. I will put HD +35% Springs in the factory struts. I will lift with spacer 1 inch.
Any other suggestions or tips?
tron67j
Maryland
If you have a 5th Gen with the snowplow package you shouldn't need anything else. If that isn't your vehicle Boss doesn't make one for that application.
N
nweselovs
USA
No plow prep package...there is a plow setup I bought straight from Boss. I have headlight harness and all the wiring. I was not paying 1800 for install.
Looks like a good size job. I will take the Air dam out first I suppose.
zrock
canada
im guessing this is a 2500 or bigger. Install the struts with the coils with the extra load capacity and lift their are posts everywhere with people having issues with the spacer lifts.
