EdGs
Getting set to change my brake fluid, hopefully this weekend. Have a few questions.
2015 Ram 1500 SLT QC 5.7 2wd 106k miles
Pressure bleed or vacuum bleed preference?
I can do either way, have constructed a pressure bleeder, and have access to a vacuum pump as well.
If pressure bleeding, is there a spec for pressure?
I figured <10 psi.
I do not have a scan tool to cycle ABS., but can take it out and activate the ABS manually and rebleed.
Any special concerns or pointers?
Thanks in advance.
I figured <10 psi.
Thanks in advance.
