Brake fluid flush/fill
EdGs
FL
Getting set to change my brake fluid, hopefully this weekend. Have a few questions.
2015 Ram 1500 SLT QC 5.7 2wd 106k miles
Pressure bleed or vacuum bleed preference?
I can do either way, have constructed a pressure bleeder, and have access to a vacuum pump as well.
If pressure bleeding, is there a spec for pressure?
I figured <10 psi.
I do not have a scan tool to cycle ABS., but can take it out and activate the ABS manually and rebleed.
Any special concerns or pointers?
Thanks in advance.
Daw14
South Florida
Why not just gravity bleed the system, just crack the bleeder and done,no other tools needed?
EdGs
EdGs
FL
Turns out I was short on fittings for a vacuum bleed, so I just had the wife pump and hold the brakes while I bled at the calipers..
My fluid still seemed a bit dark at the reservoir, but I ran 1-1/2 quarts through it and fluid ran clean at the bleeders.
I am close to needing new pads, so will probably just rebleed when I change those.
Pulled the cover and changed the oil in the rear differential too. Oil was semi-dark, but free of debris, so life is good.
