Brake Pads
Damon7278
Fort Lauderdale
Looking to get new brake pads for my 2014 ram, what is a good franchise place to go and need to get my rotor shaved down as well, the place i usually go to doesnt work on rotors....
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Like NJ said most do not turn rotors anymore as they are thinner now from the factory and may not meet spec after being turned !
Plus Rotors are fairly cheap.
I also went with WAGNER OEX Pads and WAGNER E Coated Rotors as I live in the rust belt !
Wagner OEX pads. If rotors need to be worked on IE warped or out of spec, just get new ones. I like wagner rotors, painted middles solid rotor no gimmicks. Get brake fluid replaced, number one maintenance issued ignored.
czervika
Punta Gorda FL
I had this in my wish list cuz I wanted Power Stop... https://smile.amazon.com/dp/B005UB9...olid=3EFH89G46Y0ME&psc=1&ref_=lv_ov_lig_dp_it
But should I get the Wagner pads instead???
Get the full kit. You won't be disappointed.
In April they had the full set for $345. Worth every penny.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Like Burla said the OEX almost
dust free and work well in all weather at least for me :)
Phirebeard
NW PA
I believe O'Reilly still turns rotors and drums. Though finding someone that actually knows how to use the machine... lol.
Phirebeard
NW PA
I can just get Wagner OEX pads from O'reillys ... $72?? that sound about right
$72 sounds about right from a retailer. You might save a few bucks getting them online, but if you dont want to wait get em.
2012RAM1500RT
NC
co-pilot
houston,tx
joelmic
stl mo
2022 Ram 1500 Big Horn 4dr Quad Cab 4WD SB
If your not in a hurry ....you can get them for about half that from RockAuto...
Oh I'm not in a hurry at all... so THNX for that. I have some extra $$ and just planning ahead before winter
joelmic
stl mo
Shipping at RockAuto kinda sux but it still saved me big $$
got what I needed... THNX again
indept
South Jersey
Problem with cheap rotors is you get what you pay for. a decent rotor costs about $90 or more. Most likely, if you buy the cheap ones (which are still about $65) they will warp fairly quickly. As for cutting them, I have a brake lathe and cut my own. I measure thickness before and haven't had any issues with not meeting spec, Usually have at least 100 mills above spec after cutting. typically I only need to cut 15 - 20 mills off to true them up. bottom line, don't cheap out on brake parts, they're what keeps you out of the trunk of the car in front of you.
