Brake Rotors
Nanuk
NEW JERSEY
2011 RAM 1500 Big Horn Crew Cab
Hi Everyone , new to the site , I was going to due my brakes all round being fronts are due . Thinking of upgrading to cross drilled vented all round , has anybody done this and what brand worked best ? Thanks in Advance
audio1der
Airdrie, Alberta
Cross drilled are a terrible idea IMHO. Even rotors which are cast with the holes (Porsche, etc) can crack over time, and they don't drive in conditions like a RAM on the street would.
Slotted rotors have many of the benefits but keep the strength and mass in the rotor which the cross drilled's lose.
Not only does drilling weaken the rotors, it removes mass which decreases the amount of heat it can hold/dissipate. Not sure why anyone would do that other than for looks.
Check out Powerslot's cryo-treated rotors if you're set on something fancy. They'll treat you well.
UNBROKEN
2012 Ram R/T
To be fair ANY rotor can crack over time.
I've read as many articles about drilled rotors being bad as I have about them being good. Anything that's abused can fail...holes, slots or plain.
N
Nanuk
NEW JERSEY
Never thought of it that way , I just want whats best for daily driver occasional towing , very little off road , tires haven't been changed but if I do not going much larger , have you used Power Slot product on ur dodge
Chewy
Bettendorf IA
V8
I find slotted are great for a DD. I put a set of DBA rotors on my G8 for DD driving with a set of HPS Hawk pads and couldn't be happier. Now that it's a GQ, I'll probably step up my game to a complete Wilwood setup.
BlownGP
Houston/Baton Rouge
x2 buddy
audio1der
Airdrie, Alberta
No one is disagreeing with you, but for how he will use them? Not the best choice choice I'd say.
BlownGP
Houston/Baton Rouge
Doesnt matter how he uses them, unless he plans on doing some auto x-ing. Drilled/slotted rotors will be fine a daily driving.
