Broken Stud in Head
srv010
Harrell's NC
5.9 magunum
Hi, I have a broken Bolt and stud in my 5.9 cylinder head on the driver's side. Whats the best way to remove them? Thanks a head of time!
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
There are a bunch of ways to remove them. But first i'd reference a pretty good video from a guy who goes by AVE on youtube.
https://www.youtube.com/watch?v=jnF9_LotHCU -dinking around with WD-40, or other rust penetrators
https://www.youtube.com/watch?v=fqZYgReuywM -Chemical removal
https://www.youtube.com/watch?v=1uwz7BhAWZE -has some methods useful for bolts
He covers some tried and true methods, as well as plays around with some 'home remedies'.
I think he covers it briefly, but if its sticking proud of the surface by an inch or so, you can weld a nut to it and try to back it out that way. If its flush or below the surface, this video is going to be your best bet.
dapepper9
Iowa/Nebraska Border
5.9L V8
Which stud is it? Personally i see this as the perfect time to upgrade both the bolts/studs and the exhaust itself. Header swap! Lol
Or if you're just looking for simple repair you can follow the links above. One method i really like is while the head/manifold is still hot use "freeze off" on the just the stud. Shrinks it away from the expanded hot. That and these sockets make most bolts easy.
dapepper9
5.9L V8
I used em on my header swap. Little one will grab the studs like a **** and not let go. Took a hammer to get the ******* off lol
S
srv010
Harrell's NC
5.9 magunum
Thanks, I will have to buy some of them and give them a try!
