Bumper sensors
trevorsworth
4.7 V8
I recently converted my 2011 to dual exhaust using a 2014 bumper with the dual exhaust ports. It looks (and sounds) kickass but the only bumper I could get my hands on for under $300 was this one, with holes for parking sensors that my truck can't use. I figured I'd just get some plugs at the hardware store and call it a day.
I have tried every plug and cap I could find at Home Depot and Lowes, none of them fit well enough that I'd trust them to stay & they look bad anyway. I decided to just install the sensors and not have them hooked up. I can buy all four sensors for $30, but the bezels are $20 apiece everywhere I look? Is that right?
If I'm going to be spending $110 plugging these holes anyway, is there an aftermarket kit that will fill the holes and actually give me working backup sensors?
Ledawg
Indiana
2013 Big Horn
I had the same situation. Does the bumper have the outer plastic fitting that the actual sensor fits in? I had those so I found a piece of black plastic. Made my own sensor plug. When I got them to fit right, I glued them in with gorilla glue. Once glued in I took a rattle can of undercoating and sprayed them on the back side. You could not tell they were not actual sensors. It really looked good.
T
trevorsworth
4.7 V8
Unfortunately no, mine came stripped (even had to procure new mounting brackets). The bezel pieces are $20 apiece but it's starting to look like I don't have a choice, I never would have thought these little plastic suckers would be the most expensive part of a bumper swap.
What about Hoffman KO seals? They are used to seal unused knock outs in weatherproof electrical boxes. They come in both grey and stainless steel. Don't know if 1/2" ones would be big enough, a 1/2" knock out is 7/8" in diameter (the KO seal will be slightly bigger). 3/4" knock out holes are 1.125"92F112-40.jpeg
joshhhh
